Root [BATCH] Froyo 2.2.1 Automator
savoxis
Android Expert
[BETA 5]​
I created a batch file to automate http://androidforums.com/ally-all-things-root/263285-guide-froyo-2-2-1-root-users.html by Trident. It just goes thru the steps almost identically. Run the batch as administrator (right click run as admin)
Works on either XP or Vista/7 32 and 64 Bit
BETA 5
I dont have an ally handy. This hasn't been tested. But in theory it will work, as soon as I have some confirmations I will make changes necessary.
YOU SHOULD STILL KNOW WHAT YOUR DOING ALTHOUGH I HAVE TESTED AND THIS
WILL NOT BRICK YOUR DEVICE. (Unless you do someting really weird)
To use:
  1. Download the FROYO.zip package
  2. EXTRACT the package (extracting to C:\ would probably be the best idea)
  3. Run Froyo.bat as an Administrator
  4. Follow the steps provided on screen
[BETA 5] Changelog:
  • Fixed all known issues from Alpha2
  • Tested good, cept for some driver issues (which was entirely my PC)
[ALPHA 2] Changelog:
  • Added a check after each driver install, so users can try to install drivers again in the event they are getting the dreaded "device not found" errors
  • Added instructions to install ADB and FASTBOOT drivers manually
  • Added more instructions to the LG Utilities information
  • Added COLORS
  • Added cool ascii art
  • Made it a little more newbie friendly by use of DESCRIPTIVE WORDS
Is the zip having an issue? I try to extract and I get the following...
! C:\Users\jayfer1\Desktop\froyo.zip: Unexpected end of archive
Got very busy Ill reupload tomorrow with fixes
EDIT:
I tossed it on my home server @ http://awesomazing.com/ally
I download alot and its a consumer account so dont expect lightning fast speeds
EDITEDIT:
Alpha2 is latest and its on mAndroid
That is a brilliant idea!!!! You do great work man!!!
*One non-tech/trblshooting question*
Are you planning or working on a, "Windows XP" version in the future? (I understand that its easier to stick with one PC OS) ....just curious on how excited to get....lol
Thanks again for bringing this to the community!
I have read about some people having problems when using windows 7 64bit and using Trident's manual install method. Does 32bit vs. 64bit matter for froyo.bat?
The only problem I had was with the driver in step 4. The one posted in Ally IRC worked fine though.
This batch should work fine on 64 bit, I included the 64x ADB drivers in \DRIVERS\ you will need to manually install the adb interface drivers after pluggin in the phone no matter 32 or 64
For XP I dont have a machine to test with and dont wanna install it. If someone has run thru tridents guide on xp please contact me with the differences you had to make I can adapt the batch to work with it.
I will give this a try in a little bit. I have an Ally that I am sending back to Verizon because its MEID got wiped, but aside from that it functions fine for wifi. It would at least be some kind of test.
Ally IRC is Internet Relay Chat where the developers and users chat online (usually about telling everone to read the guide but also about sex). You can get to it here wsIrc - WEB IRC
