How long should I keep my phone on charge after activating my new EVO 4G LTE?
do whatever.. you think... makes you feel comfortable ...
todays tech and design for battery... makes it fool proof.
so here are the results of the CDMA vs LTE+ options.
I'm very busy right now, so I can't go into more specifics at the moment. But know that there is no LTE in my area.
Which do you think in terms of battery consumption would be better:
Lookout
Sprint's total protection asurion app (I do pay for their plan)
For Sprint's, I don't like their locate scan which at max is every 60 mins but I do have it set to stop checking at 60% or below.
Of course the main reason I'd want to use either is in case I lose it and can find or lock it.
I believe "Prey" (which is free and open-source) is activated by incoming texts so the battery impact is minimal.Which do you think in terms of battery consumption would be better:
Lookout
Also, my battery seems to be getting calibrated, last nights results are pretty good!
With all due respect it's obvious you're not using your phone much. You are only using 17% of your screen. The battery was in standby 29% of the time! Which means roughly 30% of the time your battery was doing zip, zilch, nadda! Its a little deceptive, in my opinion, to tout the greatness of the battery when you've essentially left it alone for 12 hours without using it. Just sayin
I used the GPS for like 20 minutes, the top part of the phone got very hot and the battery practically lost 50%. This was with TeleNav. Anybody else have this type of issue?
I had my og EVO set up so it only checks my mail accounts if I turn my screen on. How do I do this on the lte?
Pretty sure that you may have had some helper app for that like juice defender or something, yes?
I think it was in my settings and I am pretty sure it could be done on an unrooted phone. Regardless, it may not be an issue in this new phone. I have 2 gmail accounts and 1 exchange account and that is all I sync besides weather.
In HTC Mail you could set time of day schedules for each account, but I never noticed anything related to screen off, sorry.
How does this look as far as performance?
