Hey everyone, I have an anomaly. Has anyone ever seen a battery spike like this? Very strange.![]()
Looks like it was on the charger then. Next time tap the graph to be sure.
.similar to my results after flashing Fresh... over 6 hours my battery has dropped about 4%
I can live with that![]()
Is anyone else experiencing this? I updated the prl as well and changed the wifi setting back to cdma only, but my battery is discharging twice as fast.
Sent from my EVO LTE using Tapatalk 2
) up some things in the phones systems. I have sene some having glitches and bugs stemming frm the MR--and a Hard reset cured it.
) potential rats nests that could be building up in the handset.Remember!
This is a major update.
Typical major updates in Android will often leave cache areas stale, dirty, and tangled.
This can inhibit proper operation of update features -- and can even lead to the appearance of old things that were working to be broken now.
For best results, save as much as possible (consider MyBackup Pro, for example), and perform a factory data reset.
If in doubt, ok to wait - but at the first sign of issues, best to give that a go.
Since July 2010, I have never updated without doing a factory data reset.
Others on the forum will attest that this is the way to go.
Not an HTC issue, not a Sprint issue - an Android-wide issue.
At the heart of Android is a thing called the Dalvik Virtual Machine. It's what your apps run under. And it has its own cache. And updates tend to never clear that out.
That's the main issue.
Rooters know to always clear this on rom updates.
Factory data reset is your way to get it done properly if not rooted.
The battery life on this thing is very discouraging. I pull it off the charger this morning, green lit 100% battery at around 7:30 am. Surfed the internet, played a few youtube videos, send a few texts and used an app or two for about 1 1/2 hours. By 9:30 am I was only at 60% charge. Ridiculously bad battery life.
Thanks guys, yah I had LTE turned off (CDMA only). I only have a few things synching. Screen brightness is on Auto (I really don't want to have to manually alter screen brightness all the time, what a pain in the ass).
I'm holding out hope that since I just got the new LTEvo (replaced the one I got about a month ago) the battery is still trying to dial in. But then again I did get it with absolutely 0 juice left in it, so I'm wondering if that causes a problem.
However, as an example, I looked at your guy's two posts and checked that I had CDMA only, made sure I was on auto, then went in to my browser to check out how to do dimming settings (how do I do that?), and my battery dropped 2%.
I'm giving this guy one more shot until this weekend. I happened to walk in to a Sprint Store during lunch with my coworker who was having trouble with that low memory issue on the OG Evo, and the Sprint guy said he thought the Galaxy was hands down better. Slightly bigger battery with blacks being displayed by turning off power rather than doing all colors at once (which he said is leading to really big battery gains), 2 gig of memory versus 1, he thought the screen was better (I disagree, I like the Evo better) and he also thought it took better pictures. He said the one draw back was no dedicated camera button . . . while I don't necessarily agree with everything, very discouraging hearing all that.
...the Sprint guy said he thought the Galaxy was hands down better. Slightly bigger battery with blacks being displayed by turning off power rather than doing all colors at once (which he said is leading to really big battery gains), 2 gig of memory versus 1, he thought the screen was better (I disagree, I like the Evo better) and he also thought it took better pictures. He said the one draw back was no dedicated camera button . . . while I don't necessarily agree with everything, very discouraging hearing all that.
I've said it before & I'll say it again, both this phone and the GS3 are great phones, it's just a matter of what each person likes & which phone is best for them. Just because you're having some issues doesn't make this a bad phone, many people are having zero problems with theirs (like me) - you just don't usually see many of those posts.What is your screen brightness? Turn it down. Turn off best wifi performance. Switch to cdma only in network settings. Change sync settings to manuel or smartsync wherever possible. Change browser settings to dim while leading pages. Consider installing Easy Battery Saver (really works). Don't use live wallpaper and use a wallpaper on your lockscreen instead of productivity or weather lockscreen.Hope this helps.
Two things - please try Open Signal Maps, and see if you jumping between towers. If so, then either your RF section is bad, or Sprint is having trouble. If it's Sprint, nothing will help this phone or the next of any brand.
Second, please post your battery usage chart, tap the graph to show details, not the one with app percentages, that's just a cartoon.
