Cheezee292
Nope these battery numbers are without any such app .. I have been getting great life on the 2 prevails in my house
Excellent! Will try it out.
Is this with Juice Defender or any other such program?
No dis but hows bout we change it to NOBLED ( New Optimus' Battery Life Extender Doctrine)
weird I did everything new optimus listed but my phone still has terrible battery life
Your battery life is dependent on a lot of things. If your phone is constantly searching for a signal it will drain the battery and if its constantly searching for a open WiFi. Everybody will have different results based on their geographical locations and phone settings.
I use Juice Defender Plus and Watchdog and I get over double my battery life with my WiFi and GPS enabled. Switching to .8 Slim also extended my battery life over .9 loaded a little
Very possible, one of the biggest contributors to battery drain is searching for service.I always keep WiFi, Gps, and location service disabled. i also keep the backlight down too, maybe its because i live in a area i with bad reception.
To test it try putting the phone in airplane mode for about 10 hours, if you can manage no calls or texts for that long
If you battery does not drain very much you know the search for signal is the culprit.
No doubt about it, as I said my optimus (which is also modified including running cpu at almost the same speed as the prevail) can last double or longer the time the prevail does.Even after doing all the battery tweaks , one fact remains ......... the Prevail is a power hungry little critter . If I plan to use my phone a lot throughout the day , you can best believe I'm gonna carry and extra battery with me . I am still very please with my Prevail and you just can't beat the monthly payment . A couple more months and I'll be down to $40 ! WOOOOOO HOOOOOO !!!![]()
Looks like I am getting over 52 hours plus on a battery charge.
Try Juice Defender Ultimate and slam it into the extreme profile for ultra battery usage. I have it on my prevail with shabby 0.9 and simple green theme and on average i get about 12 hours out of the prevail without charge.
Juice Defender is not needed .. read through this topic I get 2 days of usage without charge following what was posted here
I get 2+ days of usage from my phone with Juice Defender installed on my modified stock. The backdoor that the kernel closes doesn't even run in the background so it couldn't be eating up juice. You guys are just feeling a placebo effect.
