What version of Quadrant are yall using on CM74DX? Everytime I try running it it errors.
You need to flash the cam fix, you also need to flash this everytime you install a nightly update as well.
Just load the monster file and gps fix, them wait for final build, I'm at the point I'm gonna stop paying attention to it for now.
Ok so I downloaded the Monster.zip and the Gapps (not really sure what gapps is for but I downloaded it anyways) but I didnt see the zip for the gps fix. Is it a separate zip. Also how do the nightly s work. Do I have to install the Monster.zip first and then do a factory wipe and all that and then install the newest nightly or what. Like I said I tried to sift through all the post to get my answers but there are so many. ...Gapps (not really sure what gapps is for but I downloaded it anyways)...
These apps include Gmail, Maps, and the Android Market, just to name a few.
Can we update the nightlies (from 7-9) without wiping data?
I am still getting horrible battery life. I am still sitting on #7 to see if it evens out some. I did a battery calibration right after flashing #7 and I thought it might have been a little better than #5 but still can't make it through the day. Phone usually dies around 5:00pm everyday. I have excellent coverage (usually between 4 and 5 bars).
Oh and I have the larger standard form factor battery.
I'm not sure if there are any important apps that the Gapps package installs besides the market, now.
Yes.
Thought we were supposed to be wiping dalvik cache before installing each nightly?
For the nightly updates If I just installed the monster.zip do i need to install 0-9 or do I just do the 9?
He asked about wiping data (i.e. factory reset).
Each nightly is a full build. You only have to install whatever nightly you want to run.
Which Nightly do all of you recommend?
1. Wait. what? Is this quadrant score right? Over 2k stock cyan?
2. Alright, who stole my network identifier? It's gone!
