chevanlol360
Android Expert
Thanks to my very good friend mavrikmeercat for telling me to edit the build.prop and adding a couple lines.
This new build.prop that i edited actually speeds up your phone from somewhere to 20-30 percent and also reduce lags. Its very easy to install the new build.prop please follow the directions below.
Lines added:
ro.config.hwfeature_wakeupkey=0
windowsmgr.max_events_per_sec=150
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
persist.adb.notify=1
debug.performance.tuning=1
video.accelerate.he=1
ro.media.enc.hprof.vid.bps =8000000
ro.media.capture.maxees=8m
ro.media.capture.fast.fps =4
ro.media.capture.slow.fps=120
ro.media.capture.flashMinV=33000000
ro.media. capture.torchIntensity=40
ro.media.capture.torchIntensity=70
ro.media.panorama.defres=3264x1840
ro.media.capture.panorama.frameres=1280x720
ro.camcorder.videoModes=true
ro.ril.disable.power.collapse=1
pm.sleep_mode=1
windowsmgr.max_events_per_sec=180
ro.media.enc.jpeg.quality=90
[FONT="]ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000[/FONT]
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
ro.lge.proximity.delay=150
mot.proximity.delay=150
Changes in version 0.6:
■ 3g tweaks!?!?!
Make a backup right now!
Downloads Link
build.prop version 0.6
Build.prop version 0.5
Instructions
■ Place the downloaded "build.prop" on your SD card
■ Use a root explorer or a file explorer than can edit system files
■ Copy the downloaded "build.prop" file
■ Navigate to /system
■ Place the new "build.prop" file in /system
■ it will ask to overwrite the existing one please select yes
■ Once done copying reboot the device
You should see some difference with speed, media performance, and less lag on your Warp.
Say thanks to:
Snake X:
Provided the stock build.prop file so i could edit it
Androidxd:
Tested for difference in speed after the new build.prop was replaced
Lines added:
pm.sleep_mode=1
pm.sleep_mode=1
■ 3g tweaks!?!?!
Downloads Link
Instructions
Say thanks to:
Snake X:
Androidxd:
maybe its just my phone but I'd deal with the poor battery in order to have swift speed I may have to switch back to the previous one...thanks for all your hard work and effort...you rock
:beer:
