jetx2x
Android Expert
So hello guys... As you may or may not know I am working on bringing the quick panel to the warp... however I am a newbie to all of this and I am now in need of help... I have decompiled the systemui for our warps and CTmod for the marquee and a the systemui of another unknown rom which I believe may be aosp based... I have modded all of the xml files (I will upload them Tomorrow) and now the only thing left to do is edit the smali files... I will attach a link to the tool that I have used throughout this entire process... it is capable of compiling/decompiling apks into smali code and also recreating the java source...
It also highlights the smali syntax to make it more readable... (the highlighting makes all the difference)... So anyone that wants to aid me in this port can hit up the link... I will create a git tomorrow so you can track any changes I make and update this post...
Simply install the executable in the zip below and it will install the tool which is called Virtuous Studio Ten... the apks I have been using are also in the zip and are labeled accordingly... apkmanager is also included in case you want to decompile manually... the Virtuous Studio needs to be directed to apktool which is found within the /apkmanager/other path... thanks in advance to anyone that wants to help
http://db.tt/jJGAG1UJ
yay codeeee
