Root [Boost Mobile] I Wireless(Kroger) Warp w/Root and Overclock
The steps i used to get root.
1. I followed the tutorial here http://androidforums.com/public-mob.../630553-how-flash-recovery-pmi_n860-warp.html, however i didnot use the data fix as it is probably for PM not I Wireless.
2. i backed up my apn to my sd card, I also wrote it all down.
3.i then flashed on the rom i wanted, Halo Jelly 4.3.
4. checked to see if my apn was correct...it wasnt lol. went to the dialer and dialed ##3282# input my msl code and corrected anything that wasnt correct.
5.Reboot, if you still dont have data, check your apn again just in case.
6. my warp had root and Data after the reboot.
7. my rom was already overclocked when i flashed it to my phone, but it uses a voltage controller from the app market.
Here is the link to the stock rom. https://drive.google.com/folderview?id=0B1GZ0G76P8ataUxGQ1RWWTl1bXM&usp=sharing backup done with twrp, i can do another in cwm if needed.
CWM Backup... upload is at 19% will be uploaded by tomorrow, but heres the link anyway https://drive.google.com/folderview?id=0B1GZ0G76P8atdzdCdURqTWk1eGc&usp=sharing
Nice R & D!... the data fix is safe... it wasn't for PMI either.. What it does is give you the ability to make a proper backup with data. If you made a backup of you stock rom, when you restore all data wiped. The data fix is already in Halo Jelly so don't worry about it now but just figured i would specify. I would be curious to see your stock rom. Would you be opposed to posting a link to your partition backup? Use this and just make sure you post a link to a clean backup you made post factory reset(regardless of the situation with the data fix). This could be helpful for everyone with the warp on I-wireless... :) I would make you guys a stock rom with this backup... something everyone needs when they get into these territories... ;)
Does the backup have to be done with cwm installed? i use twrp v2.2.1
yes the backup can be done with twrp as well...
@Skinnyjeans21: this is a partition dumper backup... I want his bootloader too... it works with adb through the recovery(TWRP or CWM). Also is the B10 patch part of the Halo Jelly 4.3?
I have rooted my I wireless warp and flashed a custom ROM. I made a backup in CWM but the md5 is not registring . two questions: will thus return me to full stock including ROM, recovery, and kernel and if so how do I do this?
using the cwm backup in the first post will put you back to stock but will not put your stock recovery or your original splash screen. :)
So how do I get the stock kernel? Is there a download?
the cwm backup in the first post, it will return you to stock kernel... download it and place all the files in a folder with the name of your choice. then place that folder in the "/sdcard/clockworkmod/backup/" folder. then you should be able to apply it with your cwm recovery.
