theminor19
flash`ed a stock kernal and this loaded just fine with the latest release so it is for a fact for me the kernal, but i want to try and get some tweaks for the 3g or whatever i can to speed it up
EXCUSE ME, did you say you can make 3g faster. I have to try it. I saw a post of an updated build.prop further down this page. Is that one that will work for improving 3g or do you have another one?
YAY!!!! My Kernel is confirmed working 100% On stock rom
This means good things are soon to come
feeling: Very accomplished,
WOW is all I can really say at this point. Still testing everything out, although i can see that the Major Players already have, but im sure you cant test to much. So far so good.
I saw someone mention swap was enabled on this rom, although the original OP says it isnt, so i just wanted to double check if it was or wasnt? ill definately post any issues if i encounter any.
is there a way to disable to screen transition animations?
Settings/display/animations![]()
LMFAO im sorry that was a dumb question, I thought because the animations were not the stock ones that that would not work. LOL thank you
So Ive been running the rom for a little while, about half a day, and it seems to be running pretty hot. How hot can this thing get before i start to worry....ive seen it up to 104F just want to make sure the phone doesnt fry on me.
go into no frills cpu control and it to on demand
Yup, its been set to on demand since the initiall install. When Idle the phone is fine (about 70F degrees), but once i start to actually use it the temp starts to jump up, if im browsing facebook or instagram, navigation anything like that the temps goes up about 30degrees (not instantly but after about 20 to 30min....at about 104F i just stop using the phone until it cools down again.
that doesnt really sound out of the ordinary.. i mean we are overclocking the processor by 60% (600mhz)
How hot due you think is TOO hot? i love the rom and dont want to switch at this point? other than it running hot I havent had any other issues
i dont think you have anything to worry about at 104, some computers not overclocked run at 130ish, thats not a healthy temp (130) but i would say 110-115 is getting too hot
Ok, Thanks so much for all your help. I trully appreciate it.
FYI second day running....No issues other that one freeze up...rebooted and everything has being fine after that. Thanks again for this awesome ROM.![]()
iam guessing that one freeze up was on the first boot?
