Root [Boost Mobile] LEVIATHAN Elegace & Elegance OC Roms Released
Dm47021
Android Expert
In Continuation Of my Leviathan Rom Series i am releasing Leviathan Elegance, And Leviathan Elegance OC (1.6GHZ)
I wanted to make a leviathan rom with a brighter interface
FEATURES
- Built on the same foundation as Leviathan XIV
- B08C based
- DEODEXED
- ZIPALIGNED
- Init.d support
- Swap Support (Not in OC Version...yet)
- Standard Kernel by DOWNTHEMACHINE...thanks for a great kernel
- OC 1.6GHZ Kernel by hroark13
- OC No Frills CPU Control
- Superphone II build.prop (Thanks again to Mhalloway for this)
- Qualcomm Specific Hardware tweaks in Build.prop
- Mi File explorer
- Root Browser Lite
- Camera ICS+
- Adobe Flash Player 11
- DSP Manager
- Updated Interface (White Elegance)
CURRENT VERSION: 1.1.2.0
Status:
Stable
-------- CHANGELOG ---------
-Added Airplane mode to power menu
-Added Silent mode to Power menu
Version 1.1.2.0:Previous Issues Resolved
-Home button Fixed
-camera button Fixed
-lockscreen Fixed,
-Force closes for some.. Fixed
-Minor Bug Fixes
-Build.prop changes, removed some code, updated version system
-Removed OTA Update center
-Changed window transition effects (for speed)
DOWNLOAD Leviathan Elegance OC 1.1.2.0 Here:
Leviathan Elegance OC 1.1.2.0.zip
NO LONGER SUPPORTED
Leviathan Elegance OC 1.0 (OBSOLETE)
FOR THOSE STILL HAVING WIFI/3G ISSUES
Here is the Updated Build.prop file
Elegance Build.prop 1.1.2.0 prop rev2
DOWNLOAD LINK:build.prop
INSTALL INSTRUCTIONS
Using root browser, copy the new build.prop to /system
MAKE SURE YOU DELETE THE OLD PROP FILE FIRST!!!
Reboot into recovery, Wipe Cache, Wipe Dalvik Cache, Fix Permission.. Reboot
Looks Cool, I downloaded it, The OC version, may give it a try tomorrow. It's late on the east coast.
Ok update.. ill start off by saying i like it alot. I like all theming youve done and i love that its oc and swap enabled. I havent put swap on yet... ill say that even with oc im not losing cdma service soo someone fixed something. Rom is lightning fast. I love it
But i did find a 2 little bugs (little to me) that i will pm you about.
Anywho in this screenshot you can see i have wifi connection and cdma service while obviously overclocking :thumbup: :D
So I downloaded and flashed this Rom really looking forward to overclocking,but as usual nothing involving and oc kernel will boot on my Warp. Freezes up in boot animation. Disappointed as to why this will not work on some Warps. Any suggestions as to why this happens?....
what firmware version are you running.. B08C ?
Great! Magnificent Work!
Only one problem for me was that my home button completely stopped working but other than that OC completely worked switching between Bluetooth no losing service let phone sleep after toggling wifi,3g,and Bluetooth and everything works good job man.
Are you clearing both caches and and a data wipe before booting the device after flashing?? Also are you sure that you are waiting long enough? Because when you clear dalvik cache it rebuilds it before going past the boot screen giving the illusion that it isn't going to boot.
It can take as long as 10 minutes for its first boot.
Why will the kernal work for this rom and not others
Well this isn't shinrus kernel because his goes to 1700. I'm guessing it's hroarks. I've heard that the super build prop has made some issues related to shins Oc go away. Maybe with hroarks it completely gets rid of them but I don't know. Down the machine is the man that should look at this kernel and set up and figure out the difference. It surprised me how nice the Rom was. He did a nice job
I did wait about ten minutes. I was clearing the caches and wiping data before flashing but not after flashing. So are you saying that I should clear both caches and wipe data after flashing before rebooting?
Thats what he's sayin.:D
