Root [Boost Mobile] LEVIATHAN Elegace & Elegance OC Roms Released
Myself and a few others are looking for a fix to the home button issue.
Just for some feedback and info, mine quit working on a stock bo6. Came on for a while then went back off. Flashed to noobV same issue. on briefly, mostly off. Has stayed off ever since then. Flashed your rom as well, and no luck on the home button. Back on noob V and still the same. no home button light.
the thing i noticed, if i plug in usb and go to usb mode, i can click home out of it./ so its a weird issue
UPDATE
ALL ISSUES WITH HOME SCREEN, SEARCH BUTTON, CAMERA BUTTON, LOCKSCREEN ARE ALL FIXED!
i rebuilt the rom using a different framework, all issues are gone.
updated the download link to forward to the fixed 1.1 Release
This is a truly "nasty" little rom...like it a lot!! Could really use the Home button tho.....cmon guys, put a little OT in. I have one real request if anyone can help me; is there a way to cut out the sound on the Boot. The look is great but can't stand the noise. "Thanks" in advance.
Download Version 1.1.2.0. Home button and all bugs are fixed. if you dont want the boot sound, use root browser, go to System/media/audio/ui and delete bootsound.mp3, thats it
Hope you know I was just messin with you about the OT, I know how much time it takes to "get-the-bugs-out". Thanks a lot about the help on the Boot sound. I'll try it in the morning. I just wanted to say that I tease my friends with my OC'ed Warp by showing them how fast it is compared to their "high end" phones. They swear I changed the case on a fancy one....they don't know anything about rooting or flashing, thats my little secret in our circle. The killer part is that I'm not the nerd in the group:D:D:D
THANKS A LOT FOR YOUR WORK...I WISH I COULD FIND A TUTORIAL ON
"HOW TO BUILD A CUSTOM ROM FOR DUMMIES"
lol Its a beast, its plays angry birds around 45Fps.. no choppiness. i know you were kidding. Hope you enjoy all my work. :D
I was downloading it while we were kicking it and will install this morning. I only wish BOOST had a little faster 3G, that would make things much sweeter. Think you could "get-the-bugs-out" of their system?LOL!:rolleyes:
A nice little ROM. I like the OC now that my BT works. Overall very nice, except for a couple of things. The template mounts won't let me delete system apps in Link2sd. Also there were a couple of freezes (one that resulted in a boot loop). Also I cannot clear the crap files out in the dalvik cache, and the app cache in Link2sd. Still a damn good effort.
Edit: I cannot percieve any change in volume from DSP or from Volume plus. I hope this helps. :-)
Thanks for the ROM. I find it stable and fast so far. I will load up all of my old stuff (apps and games) and see what happens. Hopefully, it still runs well.
Great Job! Keep up the good work!!!
ive noticed with oc it will loop, but it has always pulled out of it. if you install a new launcher for example it will loop once
i can put some more tweaks in build.prop to possibly make 3g a little faster.. i cant say how much of an improvement you will see, it all depends on your location from the sprint towers
A very nice quick rom, very smooth and stable, but still wifi issues when walking out of range of wifi and then 3g connection doesnt come back on, but other than that a very sweet rom....
Well of course your going to have wifi issues when walking out of range. your out of range. 3g should come back on.. havent experienced this
Thats the actual issue, 3g not switching back when wireless is out of range, I have no network at all.:confused:
updated version screws up wifi, in settings to turn wifi on it says error...........it didnt do that untill i rebooted......any ideas?
