This is a bug report.
- Backups dont save user data or restore doesnt restore it. It seems to be there but restore doesnt install it.
- Its to damned dark. Help an old man out and add some light.
Im working on building beta-2 of cwm, tryin to fix the usb drivers and brighten the screen for you old folk here..(not sayin names). Tryin to get mount usb to work, so you could add files to ur sd card in cwm, and avoid having to reboot to android and enabling usb mode, just to copy files such as roms and stuffs (been irritating me, especially while im tryin to test my builds of cm7). Hopefully it will be to your liking guys.
[EDIT]
I dont know about backing up the data partition, it's backing it up, but for some reason as soon as you go into the stock android, it resets everything. which is why im trying to build cm7 as fast as possible to make sure, Im not sure if it's the stock rom doing it, or if it's my cwm.. I can tell it backs up data because when restoring data, you can see your account db being restored. (all the files with the numbers). its curious, and intriguing. If someone wouldnt mind building a new rom, using the base files and removing them little by little to see whats up, would help.
weird.. I dont know how I missed it :s
until like a dummy I who had already read that it didn't backup user data decided to apply a cwm backup... I thought I had everything backed up with titanium backup... nope didn't have a backup.
Can i use root toolbox to flash recovrry?
I was wondering if maybe I should use this beta to recover? Or just wait for the beta to be fixed? I really want to be able to access USB Storage. I thought I would see about this option before posting elsewhere in the forum.You can use the stock recovery from ZTE or you can root, install CWM and then restore my nandroid backup I posted. Up to you. I also have a UOT framework zip you could try with CWM if you want.I kind of screwed up my status bar and can't seem to fix it even though I had it backed up.... so now I don't have a notification bar. I restored to factory settings and that doesn't work and even if I chmod the file it still won't overwriteI was wondering if maybe I should use this beta to recover? Or just wait for the beta to be fixed? I really want to be able to access USB Storage. I thought I would see about this option before posting elsewhere in the forum.
Ok well I'm not 100% sure, but it looks like com.android.systemui.com, but it's the notofication bar at the top. I used ROM Toolbox to add a theme (although I knew better) and the notification bar got screwed and keeps crashing. I'll check out your nandroid.You can use the stock recovery from ZTE or you can root, install CWM and then restore my nandroid backup I posted. Up to you. I also have a UOT framework zip you could try with CWM if you want.
BTW what file are you talking about?
I prefer whiskey and coke myself but whatever floats your boat bro. J/KIm running ubuntu 11.10 and the bootloader drivers are npt compatible with my os. Is wine even considerable?
after installing this and then resetting to factory data a second time now my phone won't go past the little green android screen.
It worked... thanx a whole lot... and I was able to fix a second broken Warp I had lol.You may need to use the "Handset Software Update Tool" from ZTE.
yeah, the biggest problem right now im facing is a backtrace error on compiling aosp (============================================ PLATFORM_VERSION_CODENAME=REL PLA - Pastebin.com)
But thank you so much for that. I should be able to go from there and let you know how things are going
edit: I use ubuntu 11.10 x64
