D
Deleted User
Guest
I had no problems with cwm mounting the Sd card, had no issues partitioning the SD card either. What brand and class is the card? Right now in running a 16th PNY class 10. Also worked on a sandisk 8gb class 4.
I don't know why it would be any different. I flashed the same version and didn't have any issues mounting the sd
How to you get into CWM with the phone powered off? Help please?
Try flashing the stock recovery then flashing cwm.
One Click process for installing CWM! - Android Forums the link there has both imgs
Or you could just reflash cwm
Recovery not restoring user data is a critical issue, what is recovery for?
I hope could be fixed soon.
yes i did, I just tried it again and it says E:unable to open ums lunfile (no such file or directory)
I am having the same problem.. or I get:
Error mounting /sdcard!
I used Snake X's 1 click install (but used ..beta2) using a 64gb sandisk class6, tried a 32gb patriot class 10..
Tried reflashing it.. any help would be great!
ok I swapped out the 64gb card with a 2gb.... and it works what gives!?!?
also tried a 16gb and it also works.. all cards were formatted in the ZTE Warp.
