I'm going back to n00b rom, this one keeps freezing on me -__- I have to do about 4 - 6 battery pulls.
Any working Flashlight app for this rom?
I have everything working perfect, fast and stable, except cannot find any flashlight app that turn on the cam led.
Now I can die happy Bloodawn!
This ROM missing on the warp scene was the only reason I got into creating n00b ROM, it's really where I wanted to go, I think I will make an update zip to add a kernel and swap but wouldn't change too much else! I will post a zip on a separate thread if anyone is interested in a n00b twist on this awesome ROM!
FYI for the question before, the flashlight fix has to be put in the kernel and this ROM uses a stock kernel so no, the flashlight won't work. The zip I will be posting will put in place one of the overclock kernels with swap, flashlight and overclock.
Did you clear caches before flashing. And did you restore any user apps or data after flashing?
Hi Marty, This Rom is very finiky, You have to do a full wipe. clear data/ wipe dalvik/cache.
And do not restore anything with titanium backup. All apps must be restored from the playstore. But, This Rom is very fast and stable. Very small and simple. Your phone will fly using it. This latest version has no themes yet though.
Hey blood im gunna semd a pm as well but i wanted to bump your rom. There are users on the evo design 4g who want your rom on our phones if you could oop by and create a thread as to what you would need us to do in order to get it it would be much apreciated
Ok thanks for the reply man would you consider keeping us in mind when you start a new project our dev scene is lacking a bit
Just a quick question, is there anyway to remove the time and date from the top of the notification pull down
Shouldn't there be a way to make it transparent? I wouldn't know where to look so that's why I'm asking.Nope. You can disable the status bar clock in CT settings but not the notification one.
