Root [Boost Mobile] [ROM] HaloBean 9 FINAL (SkinnyHALO Included)
New Name?
  • Total voters
    60
Well that does it... open source superuser by clockworkmod anyone? ;)
I'm gonna take it slow for the next update, marching band starts tomorrow so I'm gonna have alot less time...
Is busybox in bin or xbin in your rom. I have it installed in xbin, but symlink it to bin. Takes care of most issues
Look at what I found
Dammit i cant see the attachnent im at band camp....
I've got to install this in my dev unit and give it a run. Sounds like you've done some amazing work
Thanks Jim! :D it still has some kinks though and I wonder if it has anything to do with me not using the DSIXDA Kitchen... the way I add things is I extract the zip and make my modifications then add them to the original zip....
It shouldn't make a difference, but since I already have the kitchen set up, I could run it through and see if it makes a difference
The Play Store seems to revert back to the old Market upon Reboot. I flashed the gapps package along with the Rom. It isn't annoying but I just thought you should know.
I know I mentioned it, but that's because play store is already IN the rom so if you only need gapps for play store then you're good to go. When I removed it, I put an explanation but it was still complained about enough to make me add it in again
hey i got lmt to work on 4.3
on the app itself go to info and click on the xda thread link and update the app to the latest version. It works like a charm.
THIS IS IT
THIS IS THE POST THAT HAS SAVED ME
Dude if I could hit the thanks button a million times I'd SOOOO do it!
UPDATE 4.4 ON THE WAY
Gonna include latest LMT Pie Launcher, quickpic and flashlight updated to latest versions, and probably a few more theme tweaks. Either gonna be tomorrow night or Saturday. Real life decided it wanted to try and kill me today -__-
It truly is a thing of beauty. Only problem I'm having is I can't make app shortcuts because the app list won't show up.
Ninja Edit: If you plan on using gestures you have to set the input device to 0. Or else gestures won't work.
So how do we get the full functionality out of LMT?
You find the right values using Terminal Emulator... it seems simple enough to find in the XDA thread for LMT but its a bit of work...
Hey I got LMT to work on 4.3
On the app itself go to info and click on the XDA thread link and update the app to the latest version. It works like a charm.
I can confirm this method does fix LMT. After installing the latest version I had to go to titanium backup and convert it back to a system app, but it is working fine.
It wasn't a system app... its in the /data partition just like the PA Live Wallpapers so if you don't like it you can uninstall it
Hey Skinny, are you using DM 's new kernel in this ? Would it make It better? And what does LMT Do?
Never used it before.
Dm's new kernel? And it would make it better, my highest benches were always on his A4 tests. And LMT pie launcher is like a set of shortcuts or actions that you can bring up. You swipe from the side of the screen and you'll see the pie with info about your phone and shortcuts to apps, buttons, actions, etc. Its pretty cool.
Crap I won't be able to put out the 4.4 update today... it is coming along nicely, there's still some Modding I need to do to the ics spinners but I may just remove and go to the old one, but they'll end up super smooth so it'll be nice eye candy. LMT is ready, I think I got the superuser switch right, and I still need to change some of the spinners in apps because they're showing up differently now (it looks like two circles spinning around mow for some reason but I never put that into ANY of my theme works...)
EDIT: also gonna remove "Activation" from Settings menu and I'm also going to try and modify the power menu a bit
