LilBit
Extreme Android User
You should add Acid audio engine for the next release.
I like that idea too!!
This rom rocks dude! Just one thing I had problem with getting settings to stick with voltage control so I tryed nofrills and problem fixed. Thanks for the great work dude!
This ROM doesn't seem to have powernap yet, which version of the script would yall like to see included in the Rom, the one that locks the phone at 122 with wake up lag but saves more energy, or the one with no lag but less power saving function?
I'm using Voltage Control and I'm not having any problem with settings, did you remember save the settings as an init.d script or as startup service?
Love it! The fonts, color, battery meter, the subtle gradient on the title bar!
Great work!
A great update to a great rom!
Remarkable!!!
Halo Jelly Rom 1.99 is so perfect that should be illegal
Thank you very much
Thanks! This is a now outdated version of my theme, i have another newer and buttered up one on my desktop that I've been working on... subtle changes that really made all the difference and tied everything together better. I'm also going to implement some of i2fs theming for some system applications to get a more polished look
After that I can add in some new system apps and the powernap script too. Part of the theming isn't just images, its also the text in prompts (like a force close) which will be more jelly bean like, to go with the look and give the Rom a better feel. It's a total revamp of my theme, and also some tweaking to the Rom to kinda give it an extra push.
Basically, I'm going to try and blow the top off this for the next update.
Holy baby jebus!
HALO V 1.1
1.7 ghz
sio
Lionheart
HALO Jelly 1.99
1.7 ghz
sio
Lionheart
Winner winner winner!!!
Something tells me the Adreno tweaks are working
More compiling errors in VTS... gonna be a few days before the 2.00 update is completed. Actually, I think I'll just add in some system apps and remove others... and a quick theme tweak. Everything else will be in 2.50 when I can release it...
I restored it, because the current update just freezes the phone. But I'll try to reinstall to see if that works. Thank you!
