Skinnyjeans21
Android Expert
Made it this morning
I'll report anything I find
Thanks!
So far I'm getting hang on boot animation, gonna go back to the stock one for now. Are you getting the same issue?
Thanks!
Phone froze, normal thing, had to start download again, but it's about to finish...
I'll report!![]()
About to upload new 2.25 version, it needed a hotfix. Uploading soon.
EDIT: Hotfix taking much longer than I thought... Just need to fix the signal meters. They're messing up on the status bar and blowing up, getting all blurred and stuff.
) 3 times
Same thing;
Alien
Animation (warp cream sandwich) 3 times
Nothing
Battery pull
Again
Recovery
There you have!
Thanks a bunch for confirming that for me, I got that bad animation removed and reverted to the old one, now signal meter is left. I'll be a few hours in finishing this next release...
duhduhh dadada dadadaaaaaa dadadaaa....
Typing music doesn't really work out does it...?
No.
Unfortunately all my imagination is just sitting in the dark corner of my right brain waiting for my left brain to finish building this rom... oh its done lol uploading now and also updating OP with new link
Screenies
First benchmark, right after first flash of my own ROM
Settings were SmartassV2/SIO 122-1804
[/URL
Changelog
1.99-Implemented theme and added Adreno 205 GPU tweaks
2.20-Added/replaced the following system apps: Holo Launcher (replace ADW), AdAway, DownloadCrutch, Apollo Music Player, Adobe Flash Player. Also updated flashlight app. Updated theme. Replaced platlogo.jpg and accompanying text. Replaced all sounds with ones from Mercury Sound Pack (ICS/JB Sounds). ICS boot animation added. Raised the default speed to 122-1804 SmartassV2/SIO. "Fixed" signal meter by adding 6 bars instead of 4 (the phone is supposed to have all 6, but the 4,5,6 images were replaced by the same full signal meter-- didn't noticed it during my theming until I took a closer look at it.) EDIT: this one wasn't released, wouldn't boot due to a bad bootanimation zip. Also had a few bugs in SystemUI.apk
2.25-Added stock BM bootanimation, and fixed the bugs in SystemUI.apk. New 6 bar signal meter added/fixed.
Future updates list:
Add in Wi-Fi tethering option and CPU Control to settings menu
I know this has a simple answer but I'll still ask. I made a backup of all my use apps from noob rom using titanium backup. Flashed your awesome rom and decided to Restore them all. Was this correct or should I have done a fresh install?
Its okay to do, its not harmful to the ROM as far as I know. I know it poses a danger when restoring from different android versions, or so I've heard. I've never had any issues though.
. Thanks for the quick reply. For some reason I can't get Antutu Benchmark to initialize. I tryed re-installing and still no go. Anybody have any suggestions?![]()
Apparently there was an update that was giving other people force closes, but I've never seen an app initializing and reinitializing like this...
I tryed clearing cache, dalvic, fixing permissions, nothing works. Maybe if somebody has an older apk, that way if it works we'll know it's app and not rom.
Check this post, download Mr. Bobo's personal bloatware. It's a zip file containing all his personal favorite freeware. I believe a real old version of Antutu is in it.![]()
http://androidforums.com/boost-mobi...-ii-full-install-1-23-2013-a.html#post4511380
I just bought a new phone but tend to revert back to my warp .. I'm loving this rom
glad to hear you like the rom!
