Skinnyjeans21
Android Expert
I found an issue with phone calls, fixed it though. I'll upload it soon.
Flashed 7. No issues, but I've only been using it for a few hours
The status bar and quickpanel look great, and everything runs very smoothly
Did not get to test MMS yet. Ran Quadrant a few times on the first boot, performance/deadline @ 1.8GHz averaged 3004-3050 total score.
So far, everything's working well, great job again!
Thanx Skinny, i will flash 7 when i get home, and thankyou for the info about Texas
Might wanna check your SD card and make sure its functioning right, I've always been able to screenshot, even now and I'm running 6.2. Try backing everything up to your computer and reformatting it
It was the SD card, it was full. I got a new SD card, re-downloaded 6.2, and Hotfix/ Update to HaloBean 6.3, every things working fine, looks and runs great. The only thing that I will miss is notification toggle`s at the bottom of pull-down, I got really used to that in 4.3. Great job.
Isn't their battery tweak in 7? Didn't see that in the testing section
Do you home work 1st then play. Lol. I swear dude, I've been to 2 different stores, almost bought the sequent, almost bought the new Warp, I can't leave my phone. ******ed right!? I love her phone. She has jellybean, and it's fast! I dunno!?????
I know what you mean! I was debating the S4... but this phone has come so far! I'm completely happy with it now thanks to the talented devs here... And now that DM got the Warp I sent him CM10 dev will continue! HaloBean has become my daily driver... Downloading 7 as soon as the calling issue is confirmed resolved!
On a lighter note (yes, that was sarcasm...) Skinny, I've been digging through contacts.apk as well as framework-res and a bunch of XML and smali trying to find where the call log shows '3 hours ago' instead of the time... still no luck...![]()
BTW. How can I get my Busybox to install 1.20.2? I want it!!!!!!
And 7 is liking my 64 gig card! Idk???
Just added more battery and performance tweaks to the rom, HB7 RC1 coming later this week! I'm about to work on the crappy audio volume...
EDIT: Sounds boosted 180% sucessfully
EDIT 2: Someone remind me to update QuickPic later on... I'm gonna forget again
I've flashed 7 and don't notice any change in volume.
What are you basing the 180% on? Thanks!
Also, I noticed that the Earpiece App no longer works with the ROM. Could it be the new Audio Engines?? It worked for me with 4.3, with significant increase to the earpiece for phone calls. I've tried it on 5 and 6, but it doesn't work anymore, neither 7.
Wow! You're really committed Skinny. I applaud you. I can't wait to see these....leaked....kitkat themes. I understand the desire to move away from the warp. I would do it myself, if I weren't so darned content with the price to performance ratio. I mean really, who has upwards of 300 dollars to spend on a phone anyway, right?
Anyway, thanks for all the hard work man.
