Skinnyjeans21
Android Expert
Probably the mms/apn configuration, if you have wifi on that could also be an issue, so turning it off then sending could help.
wasnt using wifi, said size limit reached, 6.2 never reached limit, same quality and size
Crap... I'm gonna have to modify some stuff, I was able to send mms on the version of 7 that I'm working on however. I need to increase the size limit in the app though...
Look into Merc's settings on woem he changed sms and mms size limitations...
Possible bug.
I was getting crashes yesterday while using google maps, each time the app would load and work fine until the map had to move and began to fill in the blurred area around the edge. It would then stop responding until it looked like it tried to kil and reset the process but ended up killing the notification bar. The only way to retrieve it was to quick reboot the phone!
Uninstalling Google Maps now and will re-install and try it out again. I will keep you posted! LOL
Update: re-installing seems to have done the trick for now anyway. I will have to try this out while in a moving car. lol sorry for jumping the gun instead of doing this first!
Many thanks to you Skinny, i'm downloading right now, soooo happy !!!!!![]()
Thanks to you too for willing to test!!
Mind testing mms? Its my biggest concern right now...
The only problem i have is my notifications sound from Zedge never sticks........I'm gonna try the new update. This is one tough ass phone!!!!
I just flashed your new update. I LOVE IT!!!!!! I haven't done anything yet, but I love the boot screen! I hated The BOOST Screen!check out the notification sound settings in the mms app and select from there... should stick, I have Gonna Fly Now and its always stuck for me
you need an ad blocker x)
it's on here! Quick question, should I install Busybox? and when I do, It only goes to version 1.20, not 1.2.2 ... (not the highest one).... you know what I mean
is the theme for settings supposed to be white
Yeah, somewhat. That's what it's like in jelly bean
reminds me 2 much of stock
1.20 is higher than 1.2.2 btw
