drewhill77
I swear I tested this LOL
Anyways, I see the lag now, working on a fix...
One of the biggest changes I made was moving to use zRam instead of swap, I am going to try making that bigger and see if it puts us back on track, I will put out an update later. I don't believe re-flashing will solve the lag issue. If I run terminal and type free when the lag is happening, almost all the zRam is used up so I think that's the issue. I don't think the overclock settings are the cause, I have been using those for a long time. I went to zram recently. I think I didn't catch that because I rarely run the phone more than a few hours without rebooting since I am usually playing with different things for the ROM. I am noticing the zRAM seems to fill up slowly the more apps you use and eventually you just run out of memory with the current level.
If anyone else wants to test the change, here is the one I am playing with now, just flash in recovery and reboot.
Something I've been working on is using crond to schedule a daily reboot.
