couldn't get wifi to work but it was very stable for me, great work guys
I had to reboot 3 or 4 times to get it to workcouldn't get wifi to work but it was very stable for me, great work guys
I had to reveiwot 3 or 4 times to get it to work
Woooooh!!!! i enabled / fixed the hw3d driver that zte worked so hard to disable in the kernel. take that !
Dont know what that means but good job
I guess that's better graphics for us now
tried, did that like 10 times it kept getting stuck on authenticating and saying my router had a poor connection even though i was right in front of it, got other devices connected to router at full strengthwifi is funny. turn it on.. (wont show up), then reboot (it should come up in settings now), enter password, (gets stuck on authenticating), reboot again, (should be up and running now)
its still buggy, a dhcp thing
same problem, i do have another wireless router though, I'll connect it later and try itYea for some reason it won't log into WiFi at my house. It worked at the hospital but not at home. It got past authenticating but gets stuck at "obtaining IP address" then resets and does it all over again and then eventually it says "avoided poor connection". Other than that and a few lockups this ROM has been going strong for my use. Messaging works fine. Phone audio is fine. 3g is fine. Runs smooth. I have no need for cam and BT so it looks like a daily driver for me. Thanks guys for all of the hard work bringing us life for this phone again.
that was a problem for the previous JB rom, a quick reboot fixed it for meDon't know if it's a bug or something just on my end but I can make calls just fine but on incoming call the caller can not hear me, I hear them fine. I tryed fixing permissions, cleared dalvic and reinstalled rom and it still dous same thing. Thanks for all the time you guys have put into this, this rocks.
it seems audio routing needs to be fixed, mic works fine on speakerphone.![]()
