Its basicly android 4.2 rebased on cm7
Wiped everything and did a fresh install of 7.1, then flashed the latest update.
So far I've found a few things:
The time is not correct on the status bar, nor the lockscreen or settings. However, when set to automatic, the analog clock widget does display the time correctly.
Settings which required a reboot previously to take effect, such as those made on the status bar, performance settings, and others now update instantly.
Except for toggling mobile data, wifi, GPS, and the like, notification shade toggles seem to work.
Wifi signal in the status bar shows no signal at all times, although there is one, and they do display in the settings.
As others have noted, Gapps don't seem to destabilize the ROM nearly as much after Search is updated.
Lockscreen weather hasn't ever worked for me without manually setting the location. Dunno if this is true for anyone/everyone else.
I'll update with any more findings as I come across them. Hope some of this helps, and again, great work so far.
I thank u for all the hard work dm, that being said i don't see m8 on original post please advise.
so how do I get google play store on my phone?
Wow, Im gone forever and I see CM built well beyond what I started... Congrats DM, Hroark... too bad I dont have a warp anymore to test it with...:-( I would help, but i dont have nada to test my builds with. My old warp is dead, son took it into tub with him without my knowlege.... Gots me a S2 now, keep up the good work guys...
