StarScream2109
Extreme Android User
Wooo;D
Wooo;D
Lol.... ill be glad when I finally finish theming this... I still haven't started doing each individual system app...
Sent from my N860 using Tapatalk 2 Beta-5
First of all have to say that this ROM is super sweet! Props to those involvedI was wondering if anyone else is having this problem I'm experiencing. I can't set any ringtones other than the stock android ones. If I try to set mp3 ringtone (worked fine on original stock settings) there is no sound on incoming calls. Have tried multiple ringtone-assigning apps and yes, I've verified volume is turned UP lol. Other than this little hiccup I LOVE this ROM!!! Any help would be appreciated.
Yeah once i get my laptop ill be doing the samein red and black though haha
Am trying your suggestions right now. But in the meantime when I used to long press desired sound/music file a pop-up option to "set as ringtone" would appear. That no longer does with this ROM. Is that in the works to be added/fixed?
I've gotten the Skype Beta keyboard to work on the Warp Cream Sandwich ROM by basically starting from scratch again. I flashed the ROM from apollostar2109 that was here: http://androidforums.com/warp-all-things-root/569179-stock-b08c-b08-flashable-roms.html and then flashed jetx2x Warp Cream Sandwich version 1.0.1b after which I flashed the BeatsAudio, StockKernel, and MarketFix zip files from this post in the order I've listed (http://androidforums.com/warp-all-t...-sandwich-rom-v1-0-1b-released-june-21th.html). The only thing I forgot to do that was suggested that I do is to wipe dalvik and the cache.
I've just added my gmail account and everything seems to be working fine except the home key. I'm going to redo everything again and this time I'll remember to wipe the cache and clear Dalvik too. More to follow...
EDIT: Instead of reflashing everything I first tried flashing jetx2x's StockKernel.zip from the link above. It restored my Home button function. I'm a happy camper now.
PS: jetx2x, you are doing a great job with this ROM and I appreciate your effort. Thank you.
Try following the same steps that Hawg went through... if it doesn't work then I apologize... this problem will be fixed in the next version
That's actually the post I followed to a "t" except I flashed the data fix zip on top of it...
Btw, love the from thus far...looking great!
Try flashing the StockKernel.zip again. What is the data fix zip to which you refer?That's actually the post I followed to a "t" except I flashed the data fix zip on top of it...
You don't have to flash the data fix on V1.0.1b... its already included in the rom... I will drop support and remove the links to earlier versions to avoid this confusion... also did you do a data restore with cwm? That may be causing the problem...
Can you tell I'm still not familiar with how this forum site works? My apologies for the sloppy posts.Edit: I don't think I specifically mentioned it in the previous post, but did you restart normally after each flash and then flash the next update?
Can you tell I'm still not familiar with how this forum site works? My apologies for the sloppy posts.![]()
Yes, I did and everything ran okay after I finished the last update.Actually no, I just flashed it all at once, so should I start up normally after each flash?
Off topic but what do you like about Tapatalk?Lol... I'm not all that good with it either... Im always using tapatalk so whenever I get on the site from my computer everything seems foreign
Let us know how it goes. If we can help, we will be here sooner or later.That could be the problem...thanks a lot
