Root [Boost Mobile] Warp Cream Sandwich Rom [Discontinued]
Should this rom move away from Ice Cream Sandwich and Towards Jelly Bean?
  • Yes
    Votes: 146 83.9%
  • No
    Votes: 28 16.1%
  • Total voters
    174
In launcher settings I can't seem to find the key assignment we had before so I could swipe my finger up on the home screen and the launcher settings would popup. I think it was the "menu" choice I don't see now. Did you take that choice from the menu or is it somewhere else? Thanks, :D
If I accidentally deleted the launcher settings icon from my home screen, how would I access the app again?
Try updating the launcher through the play store
Sent from my N860 using Tapatalk 2 Beta-5
That did it. Seems I would have learned to check that after my experience with Quickpic. Always update the app if it isn't doing what you expect or want. :) Thank you for your excellent help. :)
Honestly this is the best community of devs if ever seen :D
Yeah... I've been on ALOT of different tech and hacking forums (just Google jetx2x and you will see) and all the devs I've ever known have been lone wolves and have kept to themselves... but on here everyone is extra friendly
Yeah... I've been on ALOT of different tech and hacking forums (just Google jetx2x and you will see) and all the devs I've ever known have been lone sharks and have kept to themselves... but on here everyone is extra friendly
Its the only way things will get done :D
Hey Jet, just wanna apologize for my bitchy attitude earlier. I'm sorry, you think you're young? I'm gonna be 15 next month. I was just in a bad mood. I'm sorry.
It's good that you can admit it. Thanks for the apology. Did you get v1.5 loaded? :)
Well I'll give you credit, for a kid, that's cool that you can man up and admit that you were in the wrong, and are sorry. (Sorry, don't mean to offend you, I call everyone younger than me a kid, even if you were only a month younger.)
On Topic: I'm gonna flash this 1.5 update, and play around with it. Cos I can't decide what ROM to use anymore, as usual xD
Prinny, you will not be disappointed. It's a very good ROM. Everything is working smoothly once I followed his steps to get the wifi working. You'll like this rom. :)
I didn't mean to sound harsh dude... I'm sorry if I did.... I was just trying to prevent everyone from messing up their phones and giving me a headache... btw it wasn't directed towards you... it was more like a public service announcement
I've found it easy to recover most of the apps that I want back on my home screen by using Titanium Backup Pro for non-system apps. I found it hung when trying to restore the stock browser from backup and I think I know why. I think it's because this ROM is deodexed and the stock browser is odexed. I simply renamed the two stock browser files in /system/app and then copied the deodexed browser.apk to /system/app and changed permissions to rw-r--r--. I think this is the link to the zip file with all of the stock apps jetx2x removed: http://db.tt/aljRmvot. I copied the unzipped folder to my sd card so I have them available if I want them. If TB hangs on a restoration, I restart and go to the next app. I come back to the ones I skipped and do them like above or install from the Play Store.
So far, everything has been running smooth on the flashed version of WCS v1.5. I really like the way it turned out on my device. If I knew how to put a picture in my post like jetx2x has on the OP then I'd put a shot of my home screen here for you to see. I like this ROM.
You can download an app called screenshot ux. I think thats what its called...its a trial version but works great
I got the screenshot with the Airdroid App from the market. It gave me an upside down shot but that was easy to rotate in Windows. So I have a .jpg file but don't know how to post it properly.
You can set the app to automatically rotate the picture... and you can use tapatalk to post it
So, i do have a question. The ics keyboard doesnt seem to autocorrect what i type. Its nothing major, but anyone else have the issue? And how did you fix it?
There's one on the Play Store that you can try to reinstall or update. It's the one by johntanmi, I think, because it's the one that says "installed" when I looked it up. I hope this helps. :)
It doesn't auto correct when you are doing things that you may not want auto corrected... like if you're entering in a web page or login information... but it works on everything else
It wont even do when I'm texting o.o then again. I cant get the ics keynoard to stick lol..must have missed a step earliee
OK, let me see if I can do this photo upload of my home screen. I like the ability to adjust the number of rows on the screen. Here goes...
You have to turn off wifi and reboot to switch keyboards
