Root [Boost Mobile] Warp Cream Sandwich Rom [Discontinued]
Should this rom move away from Ice Cream Sandwich and Towards Jelly Bean?
  • Yes
    Votes: 146 83.9%
  • No
    Votes: 28 16.1%
  • Total voters
    174
OK, let me see if I can do this photo upload of my home screen. I like the ability to adjust the number of rows on the screen. Here goes...
Nice... I haven't had the chance to do all that much to mine because of the constant flashing
Sent from my N860 using Tapatalk 2 Beta-5
I've run into a quirk with setting auto rotate off. The check box won't keep unchecked. I had to reboot like we had been instructed to do when setting up the wifi connection. Now it's okay. :D
I have no idea why wifi would cause stuff not to stick... it seems like i'll have to do some research
I don't mean to say wifi caused any problem here, although you know more than I and it might be. However, I just had to restart like I did when I first setup wifi. Wifi is working fine for me now. Switching back and forth between 3G and wireless. Now the screen isn't rotating because I restarted after I took off the check box. It's working the way I want it to now. Thanks. :)
I thought I had Wi-Fi off...apparently I push buttons too fast and it didn't register. Whoo fixed!
Lol.... what Widget(s) are you using?
Its actually a live wallpaper called moss. I like seeing what's going on in my systems like conky and such. So this is perfect.
If you download 1.5 do we have go to bo8c b4 flashing this or flash it
If you were running the previous version then you can just flash 1.5... if you were on anything else then flash to b08c first...
Am i going to have to reboot everytime i turn on wifi to get it to connect? Just curious. I love the rom, and that seems to be my only issue.
Yes unfortunately... I'm looking for a fix but for now you just have to deal with it
The rom runs smoothly no lag or anything but the inly thing is that I can't take pictures it says that my sd card is full every time I go on the camera even though I have like 1gig of space any help?
I just tried the camera and i don't' get the sd card is full message and I have 8+ gigs free:p
Try fixing permissions and clearing cache
Well, now I've got my wireless and 3G swapping like it should without restarting. I'm not exactly sure what I did but it involved turning both wifi & 3G off, waiting a couple of minutes and turning on wifi without 3G being enabled. Wifi didn't work so I turned on 3G and got what I expected...no change. Then I turned off wifi and 3G worked. I left 3G on and enabled wifi and waited a few moments until wifi indicator turned blue to my surprise. I had Internet...hooray. Now it swaps correctly when I turn the wifi on my router on and off and on and off and on again. Seems to be okay. Can anyone else recreate this? :confused: :hmmmm:
Edit: I'm still trying to make it happen again. :)
Edit again: I was able to recreate my success so I want to put here what I did. Now I can go all day without restarting for network changes. Here goes:
* I started with both wifi and 3g off. No indicator was on the notification bar next to my phone signal indicator. I had no network turned on.
* Turned 3g on and got internet connectivity. Checked with browser.
* Enabled wifi and it connected and replaced the 3g icon but had no connectivity.
* Turned 3g off, waited a minute or two, and there was no change in the wifi connection.
* Turned 3g back on and there was no change in the wifi connection.
* Turned wifi off and 3g gained internet connectivity almost immediately.
* Turned wifi on, waited a minute or two, and it connected to the internet.
I checked that network switching now occurs without my intervention by turning the home network wifi off and on. Both networks switched as expected.
Now I don't have to restart when I leave or come home. Hooray. I really hope someone else can confirm that this works. Thanks.
