Marty_Since87
Android Expert
Holo locker is really getting on my nerves >__<
it's too bad because it's a sweet little number when it's working...
I think it has this issue on every rom and different phones... they seem to be updating it a lot so hopefully it's just a matter of time.
It's easy enough to disable.Sorry about holo locker... just have to wait until it gets fixed by its devs...
Sent from my N860 using Tapatalk 2 Beta-5
It's easy enough to disable.![]()
Wow, since I unchecked the box to enable Holo locker in it's settings menu, I haven't had it pop up since. I'm in for a surprise.Don't be sorry about it bro. You did nothing wrong.
I did as you said and it came back.
Wow, since I unchecked the box to enable Holo locker in it's settings menu, I haven't had it pop up since. I'm in for a surprise.![]()
That was the same thing that happened to me and a reason I don't like it. Like mrBobo says, maybe the Holo developer will get it right soon. I haven't checked yet to see if it can be uninstalled with TB. That will be my next move...I just did it again, hope it doesn't pop up. I didn't like it because for some weird reason it disabled the password I had on it.
Let's all cross our fingers.....![]()
I just hate having two lock screens, I got rid of it before but it came back.
This happens to me too. Then again, it was happening when I was using Go Locker as well (this happend when I was using stock ROM.)
Just uncheck the box to enable Holo locker in it's settings menu, that's what we did, hopefully it won't come back again.
It seems when I put on the ota thing it messed my phone up? it was like stock freeze restarts freeze in the middle of a call. so I reflashed 1.5 1.5B 1.6 and thats it. how do I put on ota with out fking things up?
I could also be a Boostmobile thing.Hey man, I was listening to slacker radio, surfing the web and youtube for about an hour on 3g. I thought it was weird i didn't get one text, so I rebooted and still nothing, Sent one text out and 7 came in. I doubt all those people didn't send it at the same time. And i have perfect signal im right next to a tower (I was online anyway). Just want you aware. Its probably just a warp thing not your rom.
I just purchased it and it's worth the $2.99. It has so many configuration options it's going to take me a few hours to go through them all I think. Great app and thanks for suggesting it.that's what i was thinking just wanted to share it and ppl, if you don't like the boost mobile brand on the holo launcher get widgetlocker. It has root helper so no matter what the original lockscreen disappears so you will only have one lockscreen and it looks just like ics, I put my doubletwist widget on there too so when im running i don't have to unlock to change music.
I just purchased it and it's worth the $2.99. It has so many configuration options it's going to take me a few hours to go through them all I think. Great app and thanks for suggesting it.![]()
If you did tell me, you'd be preaching to the choir.No problem I bought this way back before there was custom roms, Downloaded a funny pack man unlocker and stopped using it...Redownloaded it about two weeks ago, and found out i could add widgets to the locker (go figure widget locker...add widgets..) Tons of features that i still don't know about. One thing about android...you pay a small $2-3 for an app that is amazing. It would go for $15 on IOS store. (Do I even need to state how much I hate apple?)
Ok guys... downthemachine and I got the custom pic for the kernel fixed... so ill be sending out an ota later tonight with the kernel included
