has the problem with not being able to change the time zones been fixed I live in the eastern US and I can't switch the time and that is the only problem I have with this rom...other then that I love it !! please let me know if this has been taken care of so that I can update my phone !! Thank You for all the hard work that you have done on this !!.....Cyn :O)
Has anyone tried the glitch oc kernalwith this rom? The 1.6 one. Results? Any issues?
Thanks for the informative replyWhy im asking is that this phone is not mission critical but i really dont want to be a guinea pig since my family only uses. Cells..... no land lines. So if i brick, im goi g out to buy a new phone asap, trust me when i say it would be a big inconvenience. So the question is other than a possible wifi issue... has anyone had any other problems.... what about heat dissapation? I hate my case but its a necessary evil..... id rather not have my phone go nuke.
I'll just throw my two cents in and say that I'm running the oc kernel with Warp Cream Sandwich ROM and have experienced zero problems, no overheating, no Wi-Fi problems, no nothing. Phone gets no warmer than normal even when I'm running it full out @1.612 GHZ while charging the phone and playing Temple Run etc. Hope this helps.
I have no idea what happened when you tried to get the file because I just downloaded version 1.6 from the OP without any problems. Maybe Dropbox was having some temporary trouble. Try it again.![]()
Thanks Krowbarr, I appreciate the response, did you flash Just the oc kernel and what App are you using? setcpu, No frills?
I posted my solution to the time zone issue a little while ago. Anyway, this is what I wrote:
I had the timezone issue when I went to China. Download ClockSync and TimeZoneDB for ClockSync from the Play Store. Just go through the ClockSync's preferences and adjust away. Good luck!
I tried what you suggested and nothing happened ....if I reset my phone back to stock...."non rooted" would that fix it....this is getting more and more frustrating !! HELP
