Root [Boost Mobile] Warp Cream Sandwich Rom [Discontinued]
Should this rom move away from Ice Cream Sandwich and Towards Jelly Bean?
  • Yes
    Votes: 146 83.9%
  • No
    Votes: 28 16.1%
  • Total voters
    174
I'm using CWM, and wiping data/factory reset.
Factory reset doesn't return to stock. You would need to flash a return to stock rom. Factory reset just returns the phone to the point of when you first installed the rom.
Click this Link! http://androidforums.com/boost-mobile-warp-all-things-root/569179-stock-b08c-b08-flashable-roms.html
Once you have the stock rom on the root of your Sd-Card. Use the following steps!
Wipe Data/Factory Reset
Wipe Cache Partition
Mounts and Storage
-Format
/system
/cache
/data
Advance
-Wipe Dalvik Cache
optional
-battery stats
Install zip from sdcard
-choose zip from sdcard
Then the rom of your choice for example
http://androidforums.com/boost-mobi...2012-full-version-no-root-needed-install.html
I had installed the alienwarp rom and decided to use warp cream sandwich rom. When my phone boots up I keep getting the Alienwarp logo, then it shows the team glitch logo, then the different colors with sound effect comes up before desktop. I have tried different roms and kernels and can't get the Alienwarp to disappear. I even did the return to stock that removed CWM recovery and reinstalled everything by wiping cache, all other wipes stuff. I like this rom but would like to get rid of the Alien Warp logo. Any assistance?
So I backed up my info from my Warp, then installed the WCS Rom. It was awesome. But then I realized that I was losing battery power much faster then with stock. I tried to do a factory reset, (go back to stock) but it wouldn't work. Any thoughts? Am I just noobing this up and missing something simple?
Flash the stock b08C ROM from this site: http://androidforums.com/boost-mobile-warp-all-things-root/569179-stock-b08c-b08-flashable-roms.html after clearing dalvik and wiping data to clear the cache too. That will return you to the stock version and better battery usage.
You simply need to flash the stock boot splash image... go back to the alien warp thread http://androidforums.com/showthread.php?t=626702
Look in post #3 and flash the file that says stock splash screen
Thanks.. it worked flawlessly. If I would of just ask first instead of reinstalling all the ROMS and kernel I would of save my self so much time... Thanks again... Great Work with the ROM. I have one more dilemma, to see if you have a solution. I have two ZTE warp phones and they both have your ROM and Glitch Kernel. One phone is detected through USB but not the other. I am using the same computer and I don't believe is the drivers since one phone connects with no problem. Wife Phone connects but not mines. Something must be corrupted with the drivers in the phone?
No idea what's going on there honestly
the phone might just be in the wrong mode for usb, just do this:
open dialer and enter *983*87274# choose AT
after you are done, connect usb to computer and see if your phone is recognized.
Ok. So I did some tests with Warp Cream Sandwich and my battery drain problem. I drained completely like 4 - 6 times, charged completely in between and now its lasting a hella lot longer. Good news, I am guessing every time you flash a new rom it resets battery stats to default (stock). But, bad news is for some reason I cannot boot into CWM. I don't understand how that happened because I had to have CWM to flash the WCS rom... Any ideas as to what went wrong and how to fix it?
Im not sure, if i was you i would just reflash cwm using computer. I could be wrong tho.
