UPDATED
ADDED TO "KNOWN WORKING SPRINT/BOOST ROMS FOR THE BOOST S3" Section.
Concerning the Wicked Sensations ROM.
ADDED- Link to zip for new MyHub app (replaces Kuban Updater) and MK3 buil.prop fix. MK3 buil.prop fix stops the annoying update notification for that ROM.
__________________________________________________________________
Just a note from an Android lover who's been around awhile, flashed and tested more ROMs and mods than I can remember and loves sharing information with the community. Many of which, I consider myself very blessed to call friends.
WICKED SENSATIONS
I run the Wicked Sensations ROM and have been for quite awhile now except for the times I'm testing ROMs and mods for this thread. If you're not worried about whether or not you're running the 4.3 update then I highly recommend giving this ROM a try. It's fast, stable, and the options are MANY!!!!!
Did I mention that the options ARE MANY??? lol
The stock kernel that comes with the ROM is awesome. It's tweaked and performs wonderfully. That being said and being the kernel junkie that I am, I chose to go with the custom KToonsez 747 kernel. I am by no means saying that it is the best either. I am simply saying that this is the one I prefer.
The KTweaker app that comes with the kernel is a nice addition too. It gives me full kernel control along with the option to overclock if i want to. The kernel comes with the overclock option disabled which I think was a brilliant decision by Ktoonsez. You have to actually go into the settings and enable the overclock option. I like this because you can get all the kernel tweaks without even overclocking your phone. Nice huh? Yeah, I thought so too. The KTweaker app also offers many other extras like Fast Charge. I've use this option and it's definitely nice to have if you need a quick charge and don't want to go through the process of changing the battery or working from a phone that's tethered to a charging cable. This option also disables itself when you reboot which I think was another brilliant choice on the developers part. It's cool to have the fast charge option if you need it but it's best for the battery if it's not used as a primary charging method.
Team Wicked is working hard on updating this to 4.3 but trust me when I say that this baby is a gem as is. It comes with a lot of features but doesn't come with all the apps and mods built in like some of the other ROMs do. You have the option to add what you want via the ROM thread or the MyHub app which is still in the process of being updated. You can truly make this ROM your own with the options that are available. That, the stability of the ROM, and the member base in the thread are outstanding. Many of the members are constantly adding full themes, themed apps, and mods. The ROM support in the thread is also superb! Trust and believe me when I say that there are some very talented people who help out in the ROM thread. I would list them but I would be here for another hour. Yes..... there are that many people who help out with the themes, mods, and support.
THE MOTHER OF ALL ROMS (MOAR)
Another ROM that I absolutely MUST mention is MOAR. When it comes to ROMs, it is definitely a masterpiece in my book. I am absolutely in awe at what Rompnit and Team nOObz have created! If you want a ROM that comes fully equipped with just about anything you could imagine, please give the ROM a try. I ran MOAR for a good while and it ran beautifully. It's just that I'm more of a simple kinda guy when it comes to mods and options that come built into a ROM. Many of the options incorporated into MOAR would never be used by me. For the person who wants it all and would use it, MOAR is the ROM for you. As I mentioned earlier, MOAR is an absolute masterpiece and is by far one of the best ROMs I have ever ran.
Soooooooo....... I felt like sharing a little tonight and figured I would go ahead and add it to the UPDATE I was posting instead of creating a new post. Hopefully some of the info here will come in handy. If it helps only 1 person then it was well worth the time it took to write it.
Thanks again to the members who have taken their time and have helped this section grow. I consider it a blessing to work with and learn from each of you.
