Right now I have data but if I turn my wifi on, then back off, I can't get data.
OK, how do I tell what bootloader I'm on? Maybe if I change bootloader, it might fix the problem.
Check this thread out. My benchmarks went up nearly over 7000
[4.4/4.4.x][PATCH] Qualcomm-optimized Dalvik & Bionic libraries - xda-developers
Hello, can anyone tell me if it is possible to update prl and profile on any Aosp rom?? I have tried several different Aosp roms and cannot find anywhere to do this.
Thanks
I see M.O.A.R has been up dated to mk3. Might give it a spin
UPDATE ON CM11 -
The newest 12/15 build of the Official CM11 Nightly seems to be fully functional so far. No issue when changing between wifi and data.
Where can I find this rom?
what are the major differences between moar 6.1 and moar 7.0. besides the mk3/ 4.3 update.
and is the galaxy gear supported.
arty:
*** My Quote***This thread not only contains tons of PRLs, it also tells you how to flash on both TW and gives you access to the script the is needed for the AOSP ROMS.
http://forum.xda-developers.com/showthread.php?p=35576100
UPDATE ON CM11 -
I still need to test bluetooth but so far this nightly is running great.
I'm also running the newest AOSP 4.4 747 kernel. No issues to report.
***Your question***
When I use my phone, I don't see a quote option in Tapatalk.
OK, I think I got it now. Thanks this should be it.
Ok, cool. There's a THANKS tab in there too. heehee!!!!![]()
I enjoyed hitting "Thanks" for your post about being "Thanked" ha ha ha!!
I thought I read in a post that cm 11 is fully functional and no issues with data when turning wifi off. I clicked on the link in the Op for the cm11 night lies rom and several posts mentioned the same issues with data not connecting when turning wifi off.
