jdsingle76
Crop. Just got notified that Drop Box has suspended my account due to excessive downloads. That bites. 2nd time in 2 months. :-\
Why not use androidfilehost or dev-host? Db is Bush league anyway
I'll check into then. I have never really needed anything other than DropBox to share files with friends. I guess when you share modded ROMs and stuff, that really pulls from the allotted amount that can be shared from a free account. I'll get it figured out.
Thanks for the tip.
I usually use MediaFire but they have such a small limit on the file size.
[SIZE="5"]Update[/SIZE]
WICKED SENSATIONS HAS BEEN UPDATED TO 4.3 AND ADDED TO THE 4.3 ROM SECTION
ALSO, HIIIPOWERS..... CHOMPSMS ALSO HAS THE OPTION TO CHANGE THE MMSC AND PROXY. I'VE PERSONALLY USED IT TO CHANGE MINE OVER TO BOOST FROM SPRINT.
Great so chopsms works also BTW anyone running the 4.3 moar just wondering what it looks and runs like
Is this wicked or what? Lol
I just flashed it an hour ago. I like it a lot so far. All the Aroma Installer Morphology and Themes from 6.1 is gone. Worth taking a look at.
I might flash some other Roms this weekend but I will probably use this one next week when I go back to work.
:afraid::vroam:
Can't sleep. Wetbiker will eat me.![]()
UPDATE-
ADDED FLASHABLE TWRP AND CWM RECOVERIES Thanks to Naddict to the "Odin Recovery Packages, Modems/Basebands, Recoveries & Guides" Section.
[Recovery] Flashable and the Latest - CWM 6.0.4.3 - TWRP 2.6.3.0 - Stock
[Recovery] Flashable and the Latest - CWM 6.0.4.3 - TWRP 2.6.3.0 - Stock - xda-developers
This link also includes older version of these recoveries. People, the newest flashable recoveries are something you definitely want download and keep. They can come in handy!
I just flashed and am running TWRP 2.6.3.0. It's running flawlessly!![]()
That version of TWRP was flawless for me as well. Unless something has changed, though, it is not compatible with 4.4.x, but it will flash 4.3.x just fine. The main thing I miss about TWRP now that I use Philz is the ability to name backups in advance of doing the backup instead of after. Trivial yes, but I do have OCD issues related to being a flashaholic! Version 2.6.3.1 is available, supposedly it will flash KitKat, but it was a disaster on my phone as nothing would mount and the touch screen responsiveness was almost nonexistent; I also read about plenty of other people having the same problem with that version. Thanks as always Biker for relentlessly maintaining this thread! Merry Christmas buddy!
This is probably in the wrong forum but does anyone know if we can turn the phone upside down (where the microusb is on the top) and still get the screen to orient the right way. I have auto rotate on but the screen does not reorient itself when turned this way. The screen is upside down.
I'm almost certain CM has 180 screen rotation.
I'm on the static power rom, do you know off hand if this rom has it??
If it isn't part of the Display settings, I think the Wanam Xposed module might offer it.
It doesn't have it natively, but it's easily enabled via the provided Wanam install.I'm on the static power rom, do you know off hand if this rom has it??
