If you use Philz Recovery, you can also install the Aroma File Manager.
Download the zip and rename it to aroma.zip which really means that you remove the version level from the file name.
Go to your favorite file manager, I use Root Explorer and go to the clockworkmod directory probably located on your external SD card.
Make a new directory named aromafm. Move the downloaded zip to that directory.
Reboot to Philz Recovery. There is an option under Philz Settings for the Aroma File Manager. Run it and it will install your zip.
If you don't want to create the directory and rename the file, you can just flash it like any other zip and it will work just fine.
You can customize it and it will save your settings, even though the zip gets installed each time you take the Menu option to run this.
It also has a very handy terminal emulator.
File Manager and Terminal Emulator were 2 things that I miss from TWRP so this adds that functionality.
The File Manager is pretty too with several themes and options.
When you exit the file manager it will return to Philz. I have not tried but I assume this would also work with straight CWM. TWRP doesn't need it.
Nice addition to Philz.
http://forum.xda-developers.com/showthread.php?t=1646108
Now just need to figure out the Script stuff in Philz...
