After a solid 3 hours of staring at my laptop screen....
I rebooted into the bootloader with that glorious S-OFF overtop.
congrats!
As you might understand... I was very eager to install one of those amazing roms, and downloaded and tried installing the PACman rom for the EVO 3D, admittedly (and regrettably!!) rushing a bit :/
lesson learned, ask questions before stepping into the unknown.
The reason PAC rom wouldn't boot is because it requires a downgraded hboot version.
I have a thread here: http://androidforums.com/cdma-evo-...8902-radios-hboot-firmware-all-downloads.html that has all the hboot versions for evo v and evo 3d. In the first (radio) post, there are instructions for using a PG86IMG.zip and special instructions for switching hboots specifically for this scenario (ICS to jb).
At that point I was frustrated enough, to the point where I ended up trying anything I thought might have the slightest chance of giving me my long-awaited rom.
I don't remember what I did exactly, but I flashed a few more files, actually modified the updater-script in the ROM zip.... :/
And now I'm stuck at that White n' Green HTC boot logo, it does not reboot, just stays on constantly, laughing at my hours of fruitless labor.
Before we worry about having severely messed anything up, let's come back to this part later if needed.
I can boot into the bootloader whenever with a battery pull, go into 4ext with no troubles.
Good! If you can access bootloader and recovery, you're probably going to be able to recover.
I tried using the RUU, but I have taken both OTA updates, and even when I finally did get it to start up and run, it denies me almost instantly...
what specific error is the RUU returning? Because you are S-off, you can run the RUU. Does not matter that you have taken the latest OTA or that the bootloader is locked/unlocked, etc.
What state is your phone in when you attempt to run the RUU? My advice is to put the phone into fastboot USB mode and attempt the RUU again. If that gives you an error, let me know what it is.
A few weird things... That scare me a bit...
I can put anything on my SD-card from Ubuntu fine through 4ext's USB function, but everything I do doesn't "stick"...
As in... I put a PG861IMG on the root, see it stay on the root in Ubuntu's file manager, but then boot into bootloader and it doesn't register that there is one.
This is just one example, any other files I transfer over don't take either.
Not sure if it was a typo, but it should be PG86IMG.zip
Does Ubuntu show file extensions by default? If not, make sure the file isn't actually being called PG86IMG.zip.zip
If anyone can give me a miracle reply that will save my whole life, you have no idea how appreciative I would be.
Thank you in advance to any replies and/or advice and/or suggestions, etc...
