Viet1982
I have a couple of questions but first I'm going to give a tip
If you want to disable the sound that comes on when you boot your phone you can do so by doing the following:
1.) Use an app like File Explorer to gain access to root.
2.) Make sure you have mount and have read/write permissions.
3.) Go to /Etc and within that folder there's a file called "PowerOn_standard.snd" rename the file by adding something to it like "old" for example rename it to "PowerOn_standardold.snd" That's it! You can revert back to having a boot sound by renaming it back to the original file name.
Interesting Fact: Snd files were first created by Apple, ironic eh?
Ok since I probably helped a few of you out there with that tip maybe someone could return the favor?
I'm trying to find a program for Windows 7 that will be able to convert Mp3 files to .SND files. I would prefer free software please.
Secondly does anyone know of a site that has free .snd file samples?
Thanks
Thanks
