nitestalkr
>>DownLoad Links is towards the bottom of this post<<
>>>BACK STORY<<<
After flashing Quattrimus CM9 Beta1 Pre3, I was taken by the CM9 Bootanimation. I liked it so much that I imported it to AOKP Beta1 Pre1 when I flashed it. After stumbling upon Anthony's After Burner Theme, GO SMS Blood Red theme, and Apollo Red Theme, I HAD to do something about that Cyan colored boot animation... so I did an outstanding recolor job to the Boot animation, and made it red.
>>>>>DISCLAIMER<<<<<
I will NOT be held accountable for any inconvenience this may cause, I do NOT own the rights to Cyanogen Mod, or any of their proceedings. This is merely an edit of the original Boot animation.
Without further a due;
I PRESENT TO YOU, CYANOGEN MOD 9 RED REDUX!
>>Down Falls<<
-There are none. "Who cares? RED = Awesome." -Drewwalton19216801
>>>>INSTALLATION(flashable .zip)<<<<
-Download the Flashable version "red.zip" (https://www.dropbox.com/s/vlj2isu0yiuub79/red.zip)
-Place on root of SD card.
-Reboot into recovery mode
-(OPTIONAL)Wipe Dalvik/Cache partition.(OPTIONAL)
-Disable signature verification****
-Flash "red.zip" as you would with a ROM
-Reboot, and enjoy!
>>>>INSTALLATION(from phone)<<<<
-Download the bootanimation.zip, and place on root of your SD card.
-Using a file browser that has Root rights, and system R/W permissions (such as Root Explorer or Super Manager), copy the bootanimation.zip, and place it in /system/media/ replacing the original Bootanimation.zip
-Reboot, and enjoy.
>>>>INSTALLATION(using BACKside)<<<<
-Go to Settings>>CyanogenMod settings>>Interface>>Bootanimation and locate the bootanimation.zip.
-Reboot, and enjoy.
>>>>INSTALLATION(using ADB shell)<<<<
-Download bootanimation.zip to your computer.
-Enable USB debugging on your device in Settings > Applications > Development.
-Connect your device to the computer via USB.
-Launch a command prompt/terminal window on your computer.
-Navigate to the location where you have the bootanimation.zip file saved.
-Rooted/Unrooted devices:Enter these commands:
OR Rooted devices only: Enter these commands:
-Reboot, and enjoy
>>>DOWNLOAD LINKS<<<
CyanogenMod 9 RED REDUX(Flashable .zip "red.zip" unsigned. THANK YOU TVALL!!):
CyanogenMod 9 RED REDUX:
http://www.mediafire.com/?9ewf3d9mhffwr93
CyanogenMod 9 Original:
http://www.mediafire.com/?dh6i441g8ewe2t6
>>>Working On<<<
more boot animations!!
>>>BACK STORY<<<
>>>>>DISCLAIMER<<<<<
>>Down Falls<<
-Reboot, and enjoy!
-Reboot, and enjoy.
-Reboot, and enjoy.
Code:
adb pull /data/local/bootanimation.zip c:\
adb push bootanimation.zip /data/local/
Code:
adb pull /system/media/bootanimation.zip c:\
adb remount adb push bootanimation.zip /system/media/
>>>DOWNLOAD LINKS<<<
>>>Working On<<<
