Root Bootanimations and Splashscreens!!!!!!!!!!!
ocnbrze
DON'T PANIC!!!!!!!!!
hey guys,
i just saw these so i thought that i'd share it with y'all. these are really cool boot animations and and splashscreens.
for bootanimations just go here:
[BOOT & DOWN ANIMATIONS(EVEN SOUND)][TeamDART] For LTE (Taking requests!)[67 today] - xda-developers
and go to post#3 for directions.
for splashscreens go here
[SPLASH][TeamDART] Over 99 Custom + 39 Stockish | Requests/Challenges Welcome!! - xda-developers
these are flashable files done in recovery
how to do your own splashscreens
so i tried the bootanimation so far and it would not work on cm10 for some reason. it said that there was a problem pushing the animation to the phone. not sure what the problem is. i might nandroid restore back to viper and see if i can get it to work.
did you try flashing it via the recovery method or the system method?
I haven't tried either way, but he says to try in recovery if system doesn't work.
COOL BEANS!!!!!!!!!
works with sense roms. so far it does not work with aosp roms. gonna see if i can manually add it to cm10 as i'm really digging the rom better then viper at this point.
edit:splashscreens works with cm10. just flash it in recovery.
Ocean in order to get it to work on CM10 do the following
extract out the bootanimation and change the name from SPC_bootanimation to just bootanimation. Go to /system/media and rename the old one bootanimation.bak or anything else and then copy the animation you want to use to the same directory. IMPORTANT make sure to change the permissions to rw-r--r--
reboot and voila you should be good to go
yeah i know. i'm lazy LOL was going to do that today, but I was slowed down by booze and football. LOL
thanx for posting that though.
