johnnyl1111
Android Expert
i posted a build in the lounge and discussion thread with rotation working.
http://androidforums.com/5808144-post46.html
I recently got my nexus 4 so I have a spare motion if you need anything tested just pm me..
I will try once my other nexus 4 gets back but I do know when you put the Sim in the n4 it says metro that's all I've tried so far soon as my other gets back will post results
Awesome. If it works with the metro sim in the N4 I'll definitely buy one, I use my phone for data only like 99% of the time so if I can keep metro's lte (tmobile's network isn't too great around my house/work), and have a nexus 4, that'd be awesome. I'd just keep the motion in NV mode for voice/text and the nexus for lte data.
oh, and if it does connect to metro's network but doesn't actually connect to data, you need to go to settings>more>mobile networks>access point names>add>name can be anything, apn use internet.metropcs, then save and select it.
There's a lot more to the APN settings than that.
I threw my sim in an unlocked at&t one x,I have no problem connecting to T-Mobile lte (1700mhz) with a T-Mobile sim but with a metro sim it shows metro in the network list (actually shows 311660) but when I try to select it a message pops up saying your sim does not allow connection to this network,I'm guessing its because metro checks imei along with the sim id. fwiw it did show my correct phone number and iccid in settings on the one x. I'm gonna try the T-Mobile sim in the motion on lte only mode once I remember to flash it back to stock,it shows my phone number and can read my texts off the sim,we just can't put it in gsm mode,I'm thinking lte should work though,so the phone is kinda future proof as long as you don't mind using VoIP apps for voice,and with my average latency being 19ms I doubt that'd be a problem.
So....can you get any kind of connection to T-Mobile??
i have no idea but if you are please keep trying XDAm I the only one still here trying to fix the mount locations and play store problems?
All the people working on this should get a group me or form a hangout to keep in better contact. Seen way to many roms die like this
actually irc works best.![]()
