Root busy box problem ?
is your admire suppose to vibrate alot when installing busybox like it vibrates alot alot more than when you root it s is this suppose to happen it did not vibrate that much when i put busybox on my old m835 i was using
busybox installer from JRUMMY16 because his version is better than all the other ones so is it suppose to vibrate that much.
my admire randomly vibrates when i went to install busybox (in a other thread)
my phone vibrated like crazy so i stopped it from downloading by pressing to he home button so is this suppose to happen and my phone vibrates so should i do a factory reset :mad: because today i was just done restoring all my apps info and things like that so any ideas i reboot my phone but it still does it.
Most of the time when in a app it said app stopped unsuspecting but there is no prompt and i am not even using my phone so can of you guys help i would do a factory reset if i have to but not today.
sorry for yelling most of the time i just need help BADLY
Sounds like a force close cascade....
Um.... I'd try a factory reset first and a double check on root status.
If it keeps up restore a good backup or return to stock with Odin.
dont forget busy box installer app. i run 1.18.0
I just installed busy box by the same dev, while installing it vibrated like crazy. it had to be force closing something, but I think I found the fix. download an app from the market called fix permissions. in the app simply click busy box installer, it will fix the permissions and no more vibrating. at least on my end. give it a try
