I bet he is getting pretty tired of redoing the theme every two weeks when a new leak trickles our way.
Man....you guys sure can bust a guys bubble...
I went back to a fresh base of 595 rooted and deodexed. Took the plunge and tried it and thus far all works as expected. I am letting the apps install and and then I will play around with it to see if anything appears not to be functioning correctly without any force closes thus far. All thanks to the devoper I just tested it because all the white is just not working for me period lol lol...So just passing the information along to those who may want to take the plunge but were not sure of the method or if force closes were in their future for trying it lol lol....Have an awesome day...
Just to let you guys know, I'm glad you guys enjoy BWC, but I'm still on .591, and most likely will wait until the OTA to do anything, unless it's going to take a while to root the OTA, then I'll get on it.
I'm busy this whole weekend, and if the OTA really is coming some time between the 10th and 13th of this month, I don't want to do so much work twice so close together.
Sorry guys, but I hope you understand![]()
Yep mine works for managing applications...Was able to do all functions...May have just been a fluke but thus far I have not found a hiccup...This one and another theme are my favorites thus far as they are both basically black all over which is just how I like it...So between the 2 themes I will be good to go until they are both officially updated for the OTACheck Manage applications in Settings, it probably doesn't work.
What kernel # and build # do you guys have in "About phone" for .595?
Build - 4.5.1_57_DX5-25
Kernel - 2.6.32.9-g0bae333
I'm really trying to understand. When you are on another build and you use a theme from a previous build (or the crt mod), doesn't it cause you to go back to the framework version that the theme was made on?
Yes the CRT Mod works just fine on 595..See the kinks below for a couple of themes that work just fine on 595 and a 595 CRT Mod but I think both of these have the CRT built in so you can check first before installling...EnjoySqldroidx does the crt mod still work on 595? Also what is the other black theme you speak of?
