Root Calculator Widget
EvoInAz
Does anyone have the HTC calculator widget? I changed ROM's and when I try to Get More Widgets from HTC it doesn't work. I have the Calculator app but I am looking for the widget.
While my buds are having you work really hard to restore a small program I would encourage that instead of reinstalling nandroids and all that mess that you use Unandroid I found this over at the XDA forums a while back. Tried to find the Thread but had no luck everyone wants unyaffs which will work as well. Anyway the OP of the thread I am discussing makes this a simple process.
You will need
1. unandroid
2. Terminal Emulator
flash unandroid through recovery reboot into ROM and in Terminal Emulator type:
SU < Then press enter
unadroid /s
navigate to the folder where the nandroids are and pic the one you want to extract from (in this case System.img)
will be placed on card under nandtemp/nandroid name/system
or something very close to this haven't done it in a while.
Note again this is not mine. I really wish I could remember the Guys name or where to find the op he deserves all the credit for this.
Here much Better directions than mine. I found this post and it was here not xda ocnbrze will probably reconize the OP
http://androidforums.com/evo-4g-all-things-root/319602-read-copy-contents-nandroid-backups.html
do it this way evoinaz
