slimbobaggins
Reset all app preferences, and it broke the wifi lock. No idea what the offender was
Went ahead and installed the update, and was able to disable the wifi scanning, but my wifi is still locked on. Has burnt through 10% of my battery life in the last hour and a half to two hours.
The wifi setting is of course "off," I tried putting the phone in airplane mode, and have started uninstalling apps one by one, trying to find the offender.
I unfortunately don't have a way to compare as I got the update on the day it was released which was the day I got my phone haha.Maybe? I don't know what it was, but it hasn't returned, and I swear my battery life seems better after the update than iy was before.
@slimbobaggins
It may not be fixed I Just realized something today. Although my wifi usage time does not increase the used power amount does. I was at 285 mAh used at 15 minutes of wifi on time.
Now I am at ~700mAh used at 15 minutes wifi on time. About 6 hours of time inbetween these readings.. Interesting.
I am at High accuracy GPS but I have wifi scanning disabled. Which on other phones actually disabled power usage also...
Gonna reset app prefs. And see if that fixes.
Same deal here, Cavell. I used wifi for about 30 minutes the other day to download a couple of apps then turned it off. By the time I was ready to charge the phone, wifi accounted for 30% of battery usage and it had been turned off the entire time. Scanning is disabled, no apps have got permission to turn wifi on for location.
Not fixed, but improved. I'm still getting almost 3 days of uptime without trying too hard.
So the issue happened again today and reboot stopped the drain. So when you are ghost drain just reboot. It is a system issue not an app, android not cats fault.Okay, I changed things back, sorry about that guys.
Does your wifi consumption show up as its own heading on the list?
I had wifi on for an hour or two last night, and it doesn't make my list, and I'm on day 3 of this charge. I probably had it one the prior day as well.
This sounds like a good possibility as I have the wifi lock constantly also but I use google play services so much (android wear watch, and alot of other google services) for me to disable things is not why I buy a phone. The issue was fixed in MM fairly quickly, Cat just didn't pull from the correct device/build tree and should of went to the newest version of MM before releasing the phone especially since Nougat is out.Okay everything I did in the above post seems to have broken the wifi lock.
I'm not a habitual voice command/ location services user, so I guess that's how I have avoided this experience.
This wouldn't be an issue, if the "Wifi off" switch actually meant OFF. Dumbest "feature" of Marshmallow. I spend 90% of my day in an area where I don't want my phone connecting to the wifi network, so there's no reason that I should be forced to accept the wifi radio eating my battery needlessly.
Correct, it does not.I could be wrong but I didn't think our phones even supported 5GHz? Or maybe that's just my version. I have 5GHz wifi at home and have never seen the 5GHz network.
I bought this cat s60 about one month ago, I found the battery discharged very quickly even on stand by, I have many phones but is one tops the cake in term of shortest running time, ask, what was the solution? I returned to the seller, this cat s60 has and impressive specifications but couldn't live up to what was said re battery life between charges, no not good enough.Cat S60 6.0.1 owner in Detroit on Cricket. Having battery drain issues with Android OS and WiFi using up a lot of battery as well (Even with WiFi off and disabled in the location services).
Booted into safe mode (power off, power on, then hold volume down until phone powers on) and now I've gone an hour and a half and haven't dropped a percentage in battery yet (after taking a five minute call and taking a few pictures on the standard camera too). If 2 hours gives me 1% standby usage, I should get 4+ days which is what I expect, but am not getting.
I've noticed that Google Maps keeps asking to use WiFi for improved location accuracy (Why?!?!?!?!) so that is my current suspect, though I will be looking into wakelock issues to narrow it down. This is really annoying.
Although I do agree that these are definitely good ways to save battery, I do not agree with having to do them. I spend $600 to use a phone as is, hell my Pixel last twice as long as the S60 with half the battery size.A lot of stuff has happened in here, wow.
For cavell, bandario, apf and Peteleu, I would recommend Limiting Background Data for Google Play Services (can be done through "Data Usage" or "Apps" list in settings). That might prevent constant pinging of the WiFi and positioning requests, even though they are turned off. I barely remember all the steps that I've done, but I never see wifi locks on my Cat anymore. Im averaging 3 days on a 80-20% drain - I try to keep it in this range.
Also I would recommend disabling background data for Play Store, Maps, Google app and whatever other apps you suspect are being little bitches. Doing it for the Play Store does require manually updating every once in a while from the Store, but this is just 2 clicks anyway.
Also, after each update, delete the entire internal Cache.
The biggest factor that helped my battery was limiting the network to 3G only, as anything above is much too fast anyway to utilize (IMO), and spends a lot more power: "Data usage" -> settings button (top right) -> "Mobile network" -> "Preferred network type"
Being a software developer I understand the importance of optimization, and if every other OEM can optimize 6.0.1 to remove battery drain then Cat can do it also.
Thank you for the tips and I am sure they will help someone else, but IMO they should not have to be done.
