wow,this looks like potential good news! :smokingsomb:
i wonder if your battery is shorting out,or flakey?
id run the .exe for the build your currently on(this one:
Shipped ROMs case you need to up,you can.
youll need to relock to run it,or a full PG86IMG in hboot.
if you select fastboot,does it go? or turn off?
put phone in fastboot,open cmd,then
fastboot oem lock
youll prolly get a
security warning since youre on a custom rom,wich is no biggie.
run the .exe with the phone in this mode. cross fingers
since youve got a charge light now,i think id give it some time to see if it turns green
if you cant get the .exe to run,you can extract rom.zip,and rename to PG86IMG,or just download the .zip:
Shipped ROMs
i do beleive they are self checking somehow,and will not run if they have somehow become corrupt. ive had a few instances where they would start,then flash off and disapear. redownloaded,and they worked
