DragonSlayer95
Resident Air Bender
What do you mean that it wouldn't work? Was it throwing up an error message?
Blah didn't mean not work, rather when I went to download exe, I keep getting an error that the exe doesn't exist via scotty's link
DS
DS
Did you try downloading from shipped roms? You're on 2.17 right?
Which one are you trying to download, the exe should work if you have the correct one.
Checking in.
Fastboot usb showing up. Downloaded the ruu zip and renamed PG86IMG since exe wasn't working.
Booted into fastboot and ran it. Now it won't get past boot loader when trying power on normally.
Any ideas?
DS
Checking in.
Any ideas?
DS
Did you use fastboot commands or actually update through the bootloader? I'm not 100% that you can use a PG86IMG version of the RUU through the bootloader because you are s-on. I might be wrong (Scotty will have to verify) but with being s-on, you are limited to what partitions you can write to, and I think some of the items in the RUU are some of them. The boot partition I think being one of them... Normally s-on users have to flash the boot image through fastboot commands except when using smartflash with 4-ext. I probably made this way too confusing but to sum it up, I think you have to be s-off to run the PG86IMG version of the RUU...![]()
Did it sucessfully update all partitions?
Is it hanging at the splash screen,or is it literally just going to hboot wen you power it on normally?
Sounds like nothing got updated... So hopefully getting the update to work will give positive results
For the getvar all:
-open cmd window
-put phone in fastboot. plug in
-enter command:
fastboot getvar all
-copy and paste the output![]()
Do I need to run the Ruu again before doing this?
DS
C:\sdk-tools>fastboot getvar all
INFOversion: 0.5
INFOversion-bootloader: 1.50.0000
INFOversion-baseband: 1.06.00.1216
INFOversion-cpld: None
INFOversion-microp: None
INFOversion-main: 2.17.651.5 <- main version
INFOserialno: HT18VHX07258
INFOimei: 355195000000010
INFOproduct: shooter
INFOplatform: HBOOT-8260
INFOmodelid: PG8610000
INFOcidnum: SPCS_001
INFObattery-status: good
INFObattery-voltage: 3800mV
INFOpartition-layout: Generic
INFOsecurity: on
INFObuild-mode: SHIP
INFOboot-mode: FASTBOOT
INFOcommitno-bootloader: 9ea898af28567f2124dbfa59f1398dcf5144829
getvar:all FAILED (status malformed (1 bytes))
finished. total time: 0.060s
if the .zip that you flashed was also the 2.08.651.3,then it didnt update since it failed the main version check. looks like we steered you wrong in recomending you flash that one
my excuse is that my 3d is gsm,so im not as familiar with cdma builds. and im stickin to it
c:\miniadb_shooteru>[COLOR="Red"]adb shell[/COLOR]
~ # [COLOR="red"]dmesg | grep mmc0[/COLOR]
dmesg | grep mmc0
<3>[ 2.973723] mmc0: No card detect facilities available
<6>[ 2.974150] mmc0: Qualcomm MSM SDCC at 0x0000000012400000 irq 136,0 dma 18
<6>[ 2.974333] mmc0: Platform slot type: MMC
<6>[ 2.974455] mmc0: 8 bit data mode enabled
<6>[ 2.974638] mmc0: 4 bit data mode disabled
<6>[ 2.974730] mmc0: polling status mode disabled
<6>[ 2.974852] mmc0: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
<6>[ 2.975035] mmc0: Slot eject status = 0
<6>[ 2.975127] mmc0: Power save feature enable = 1
<6>[ 2.975310] mmc0: DM non-cached buffer at ff007000, dma_addr 0x570ac000
<6>[ 2.975432] mmc0: DM cmd busaddr 0x570ac000, cmdptr busaddr 0x570ac300
<6>[ 3.099577] mmc0: new high speed MMC card at address 0001
<6>[ 3.100005] mmcblk0: mmc0:0001 KLL00M 2.25 GiB
mmc0: failed to get card ready
mmc0: reinit card
mmc0: Starting deferred resume
mmc0: Deferred resume failed
As of right now, can't move forward as I've tried to download several times from shipped and it completes at 7kb :/
DS
Are you downloading from phone or PC ??
DS
