I am going to step in quickly to get you back on track, SRS, you seem to be going in different directions, you need not get ahead of yourself and follow the advice of the guide and James, he had you going in the proper direction, but you seem to be trying to get ahead. You need to take a step back, take a deep breath, and read the guide one more time and follow it to a T and you will be fine. You can also check James thread when he first rooted his phone, you will see the process and steps, I always tell the members to read a few threads first to understand the process, now each phone is different, but it is good to read, then you make a list questions and ask, then you dive in when you know exactly what to do, sometimes when your in the middle of a process and go in different direction and then start asking your questions, it is hard to get back on track, my advice to you is to start back from the beginning and make yourself a game plan.
I will also make one recommendation, I would use 4EXT recovery over TWRP, you will have less issues, but if you choose to stay with TWRP, make sure you use the upgraded version. Most are not using the upgraded version and thus having issues.
Ok so if you changed computers did you download htc sync and sdk mini on the new computer? Any computer you use will need both of these things. I agree you are getting ahead of yourself.
If you are on step 3 you should be doing nothing with a recovery or Rom yet. The bootloader isn't even unlocked. Let see if we can get sorted out. I'll be lurking til you get back. Then we can figure out exactly where you are and work through the steps.
Yes I followed the directions EXACTLY how they were written (hopefully), I think I'm just going to delete everything and start over completely.
I don't think you need to delete everything. We can figure this out.
So you have downloaded and installed htc sync. Does your computer recognize your phone when plugged in?
You have sdk mini extracted to C:/
Did you copy and paste the text rather than typing it. To make sure it is exact?
cd C:\sdk-tools
Also you aren't typing the "quotation marks" are you?
What else have you done?
The problem is most likely that you didn't extract the sdk-tools in the exact same location as the guide. It's not a problem really but to make it easier on everyone let's get it in the right location.
Do me a favor. Navigate on the computer to the location of your sdk-tools folder. go into that folder and copy the location from the top menu bar and paste in a comment here so I can see the exact location.
When I open my sdk-tools folder the address bar at the top says this:
C:\sdk-tools
So I'm on my work computer now, I've installed htc sync and mini sdk. So now i'm on step 2. I downloaded 4ext from Donb's link and it's a .apk file, will this be an issue since the guide is written for twrp?
And just to verify. Your phone is cdma not gsm right? Are you on sprint?
So the link to the twrp in the guide is out of date and I shouldn't use it?
) but you will just use this file instead.Okay i'll use that one. Can I also use the superusersu instead of the ROM? I don't think my IT department will like me downloading a 400mb file from an unknown source haha once again I want to keep the stock rom.
