recalibrate the battery
Use the phone- Let it go to 0% drain it as much as possibile, untill it wont even turn on
then leave it on charge for a few hours, let it go all the way to 100%
that should fix it
Um, this is normal.....
My Nexus One (which is the same phone as the Desire, just with Vanilla Android OS) battery led goes from amber to green at 90% but it does not mean that the phone is yet fully charged [just charged enough if you want to remove it].
It gets charged overnight on the desk dock & I would recommend against charging via USB.
Yes it has been happening to many Desires.
What is your FW? 10 or 11?
1.15.110.11 tmobile
Wonder if its an issue with the t mob rom then
No issues on my Tmob desire.
What happens if you reboot?
Today I took it off charge, it was at 100%, it then jumped straight down to 90% a while later (with no use)
Whats going on! Do you think its a battery problem or software problem?
Should I ask t-mobile to send a new battery?
My fw update to .11 seems to have helped the issue.
I'd suggest removing apps and widgets and charge it whilst turned off to compare.
I ran down the battery yesterday until it wouldn't turn on , charged it overnight took it off charge at 8.30 and it was still showin 100% at 12.00 sent 4 texts and recieved 3 and it dropped to 95%. It's 13.15pm as i type and it's still showing 95%. At 18.45 it was still at 90% after a few more txt's
Much much better than dropping the 15% in and hour on standby and more like i was expecting
