mikekelso421
So,im using CWM version 2.5.0.7. Most of the time when wiping battery stats,it will just pause for over a minute until finally going back to the wipe screen.But it never says "battery stats wiped" or anything.And also i made a backup and it said error varifying MD5 sum or sumthing of that sort.Ive made other backups since then that have worked,but would like to know why its doing this.I since flashed CWM again through ROM MANAGER and it SEEMS to be a little bit better,but id like to know whats up.
Ive also noticed that other versions of CWM dont allow you to flash certain .zip files.Is there a "prefered" version of CWM?
Side note: is it safe to flash AR after having CWM and then back again?
