I just came back to CM after being away for quite a while. I just flashed CM7.1.0 RC1 in hopes that I can get the Google Talk video chat to work since I think that's what is supposed to happen on this build. I haven't messed with kernels since my original Moto Droid days so.. do I need to do anything other than flash the ROM? Does it require a kernel to run optimally or am I good with just the ROM? Do I need to fire up SetCPU again to tailor the voltage to work best?
Edit a second time: Where can I find the Gapps to install?
Where can i find the latest Tiamat kernel with the smartass v gov.
im loading 4.0.8 now. i didnt have much luck with .7. so far .6 and nightly 177 is my phones sweet spot.
If I recall, you just go to a sense rom and dial this "##GPSCLRX#" and then enter your MSL number ... I think....
https://market.android.com/details?id=com.esccode.msl&feature=search_result
you can use that to get the MSL number you need....
I believe you can find it here,
[ROM][STOCK][Rooted] 4.53.651.1 - Odexed & De-Odexed - xda-developers
Let me look up what odexed and deodexed meant. One, I think, lends itself more to mods and themes, but I misremember which is witch.
Odexed vs. Deodexed - PPCGeeks
I heard the texting function in CM7 is not very good, no 720p video and other little issues kept CM7 from being as good as a Sense ROM.
Is this still the case?
