Root CM7 theme (for built in theme chooser)
hey all, i am testing my skills as a theme builder and working with a team to build an awsome rom with different themes.
currently i only have a (mytheme) labeled alpha4
please fel free to downlod and install and give me some feed back.
thanx a million!!
you will need to download an app called " notification restart "
you can use it to restart the theme instead of rebooting.
heres the link..
alpha4.apk
Yes you need to include thundercats :D
Sweet I may flash back to cm to give this a try, screenies look good man, thanks for the work.
You need better signal :p
OK on to constructive criticism from what i see off hand, I would suggest that the drop down icons be of similar form. You have the 3d looking 4g icon and the rest are stock looking (well wifi is diff but still along the same form). I dont mind the form of either but uniform i think would look nicer.
OK thats all i see for now, I will give it a try and give some more input, unless you dont give a shit what I think :) then i'll just be quiet...
Also im glad you brought this over to AF. Only my favorite devs wander over here like koni. Nice to see us getting some love after all we are the ones helping everyone run this shit :)
I'm still looking into the 4g icon. I need a new template to start with. Not sure how to include walk paper yet. This is my first creation and I'm working on improvements. Need a better program. I guess that's what I get for using free software. Maybe I'll buy the paid version next time.
Thanx for the input. And yes, i do give a shit.
You might want to include a lot more thundercats stuff to it? YEAH! Like the eye in the sword, that would wake a kick ass boot animation. Or all the ringtones could be "Thunder, thunder, thundercats! HOOOOO!!!"
(maybe not that much thundercats stuff, it might only target a niche audience)
I like it!! running it now, seems to be a pretty lite affair, just changing the notif widget icons n the pulldown bar, but the icons are quite nice lookin:) nice job nightwolf :)
It was fancier but I took it down because it was you busy.
Glad you like it .
Btw, window borders, and over scroll color should be changed too
