Just flashed my wife's phone from v6 to v9 & I can't find the theme that makes the notifications bar icons light blue. Any reason why? I selected the 2nd theme in the theme app
it's not that big a deal I was just making sure I didn't miss something. she's fine with the theme. as long as she can't text, tweet, facebook, & talk she's fine. I just try ROMs on her phone when I need a flash fix lolI removed the themes to make the zip smaller and save on app space. Workshed has a zip in post 2 or 3 of his gsb thread on xda that you can flash to add them back or I can make one up tonight when I get home.
I am sure that you meant "can", but there are times when I wish there was a ROM where I can't do all of those things, too.![]()
lol. Enjoy everyone!
Condemned CM7 V10
MD5: 7d43afa002a5f855af211ea2ff60a0d1
Condemned CM7 V10 - Stripped 2 Hell - This version has a lot removed from it such as foreign fonts, over half of the ringtones, DPSManager, CM Wallpapers, and a lot of other things.
MD5: 716da859aceb54fa4019a9993fa2b984
Dalvik Wipe only should be fine but as always if you encounter issues try a full wipe.
V10 has been resynced with CM Source and has the tweaks from V9.5 added as well and also has 3D gallery rotation issues fixed. So far I've been testing ADW EX, LauncherPro Plus and Go Launcher and all have been nice and smooth with no problems for me. I still prefer ADW EX thoughlol. Enjoy everyone!
EDIT: *GAPPS still do need to be flashed after the ROM* I'm still trying to find out info on adding them to avoid any problems![]()
EEEEK..When did u do this? You are doing a grand job trying to keep me from the charge..just set up 9.5.
What's a good OC range?
Pure opinion coming. For this ROM (and really any of the Froyo or GB ROMs), minimums should always be at least at 245 MHz. Anything lower doesn't gain you any battery. If you find the phone is laggy waking from sleep - a delay when answering calls would be another sign - you can try to bump the minimum up to 480.
Maximums? 710 is almost always safe. Many people can get faster (729, 748, 768, 787). Few can get 804, 825, 844 or 864 at all, or with any stability.
There is a tradeoff between speed, battery life, and the ultimate life of the CPU, though. The faster you go, the more battery you will burn (likely with little benefit in additional performance - performance is not merely a function of clock speed), and the hotter the CPU will run, which could affect its useful lifespan.
Ok, all that said, I run mine at 604 and it runs just fine for me. I do occasionally bump to 710 but that's very rare.
604 isn't quite as smooth on mine so I prefer 710. Plus, the games seem to run better that way, too.![]()
By the way, CS, thanks for fixing the gallery. It even rotates the images faster than I remember them rotating before!![]()
It's sad that GB runs faster and smoother on this than it ever does on my Droid 1. Wish the Droid devs could work out all the bugs on that phone..![]()
lol.
CS I can't wait to get out of this hospital bed and go home an flash V10 on my Eris.
Everybody talking about is making me jealous.![]()
