FloridaShawn
View attachment 104983 View attachment 104984 No matter what I do I can't choose a different network preference...just flashed Metro 4.4.4 stock, and 4G worked, tried dirty flash of BrokenOS/CM13 and the problem persists, tried clean flash and the same thing...can't figure this out... also the radio band is set to GSM/UMTS and I can't choose a different one @hroark13 @Masterchief87 anyone, can you please upload your Ril as a flash able .zip file so I can test it to see if it solves my problem?
GoonDoc, I experienced the same thing... When I went to change the radio band, it's just STUCK on the one option, and does NOT allow selecting anything else. (The drop down menu box of choices doesn't select/drop down.)
The same goes for selecting the 'Preferred Network Type'... the 4G and/or LTE option not only doesn't exist, but of the 2 choices, 3G & 2G, it's 'stuck' on 3G, and you can't choose 2G.
PLEASE! We need a fix! My cell is my only source of internet, and it's PAINFUL not being able to get stable 4G connectivity.
Thank you.
